If the disc tray of the Sony DVP-SR500H is locked, you need the original remote or one that has matches three "feature" buttons - Back/return, Enter and On/off. With the DVD player in standby, press these buttons in order: Back, Enter and On/off. See page 6 of the reference manual for the details. The Back/return button is to the lower left of the arrow keys on the original remote. Enter is the center button inside the arrow keys. The On/off button is at the top right of the remote.
The Reference Guide is available on the Sony product support page: https://esupport.sony.com/US/p/model-home.pl?mdl=DVPSR500H&template_id=1®ion_id=1&tab=manuals#/manualsTab . The direct link to the document is currently https://docs.sony.com/release//DVPSR500H_ref_guide.pdf . The image of the original remote is available in the Start-up Guide, currently https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf .
I hope this helps.
SOURCE: SONY DVD RDR-GX315
Turn off recorder. Hold the on/off button on the dvd player for a few seconds. until "CHILD LOCK" disappears. The child lock is now disengaged...Check page 37 in the manual (I found it online -- same thing happened to my player -- I just freed it)
www.manualshark.org/manualshark/files/4/pdf_6908.pdf
SOURCE: Sony CD/DVD Player DVP-NS501P: It says LOCKED when I try to eject
What you have to do is unplug it and plug it back in it resets the dvd player
SOURCE: I need to hack the
Hi there
Follow these steps and your dvd will be able to play discs from any region.
*With the player in stand-by mode (take out
any discs and leave it alone for several minutes) press on the remote,
in this order: TOP MENU, CLEAR, POWER.
*A menu will appear with several options. Choose Option 2 and then Option 4.
*Type 12450, press enter, then type 00000.
Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvIMQI5i
*After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
Thank you for visiting
Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvI1JPoD
SOURCE: The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
SOURCE: Region unlock a Sony DVP-SR500H
Ok here's what I've figured out for Sony dvp sr500h...
To get to the hidden menu, you need to start with the DVD player power OFF
then hit
TOP MENU
CLEAR
POWER (to turn the dvd player on)
and you should now see the hidden menu
then go to option 2
then option 4
then this is as far as I get...you can enter codes here but none I've tried have worked....
the ones I've tried so far are 2812, 34570, and 12450
if anyone can figure out the correct code please post here.
