Question about JVC HD-56G786 56" Rear Projection HDTV
Why does my HD-56G786 Jvc tv has a green screen
  • digitaldump May 11, 2010
    did it happen slowly? does menu look ok?
    does the menu look ok? or is it green too?
easyab
  • 132 Answers
SOURCE: I have a JVC-HD projection TV model 56G786 and all
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
Posted on May 06, 2011
Testimonial: "Thank you so much. The solution was helpful. I will give it a try and give you feedback."
welcomejee
  • 10594 Answers
SOURCE: How do I replace the bulb on JVC HD-56G786?
Lamp replacement procedure is written in instruction manual of TV page-93 and if you need copy of same, click JVC Support.
Posted on Jun 18, 2009
  • 33 Answers
SOURCE: My JVC HD-56G786 will not work with HDMI cable.
Check your TV's video resolution setting if it matches those from the source device (same 720p or 1080i) and see if that works.
Posted on Aug 28, 2009
  • 93 Answers
SOURCE: HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Posted on Sep 07, 2009
  • 115 Answers
SOURCE: jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Posted on Oct 06, 2009
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
We have a 56 inch JVC HD-56G786 backlit projector TV and the screen just completely pixelated while watching cable. I turned it off and back on and now even it has a green screen with staticy vertical...
Some of these had problems where the micro for the Dlp gets confused, they have a jig to connect the set to a computer and download two updates on sd cards---it may or may not cure this but this is a shop repair.
Aug 29, 2012 | JVC HD-56G786 56" Rear Projection HDTV
I'm getting green lines all through the picture?!?
You are starting to have problems with the light engine. LCA90563- Light Engine w/Color Wheel (No Lamp) for JVC HD-56G786
clear1x1.gif There is currently one in stock at discount-merchant.com for $329.95
May 21, 2011 | JVC HD-56G786 56" Rear Projection HDTV
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
How to get to the lamp to replace it
I dont have a manual either but when I replaced one on the hd-56g786 I just took the screen off by removing 10 screws and had a ton of room to do it
Dec 19, 2009 | JVC HD-56G787 Television
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Closed caption
Here is the manual for your tv. On page 51 it will tell you how to turn on and off the CC.
http://server4.nodevice.com/downloads/4e1fdaec439e1d8864e7377154b583f4/hd-52g786.pdf
Good Luck and Please Rate FixYa!
Mar 05, 2009 | JVC HD-56G786 56" Rear Projection HDTV
TV won't turn on, possible lamp failure.
I would suggest, since you have some technical background, that you download the manual for your set.
This site seems to have the best prices of any around:
JVC HD-56G786 Service Manual
Nov 18, 2008 | JVC HD-56G786 56" Rear Projection HDTV
Line on my 56g786
can you see lines over your menus? if so, replace light engine.
May 17, 2007 | JVC HD-56G786 56" Rear Projection HDTV
JVC HD-56G786 56" Rear Projection HDTV Logo
361 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
