Question about Thermador CVS30R Kitchen Hood
Push button switch burned out, can i but just a replacement push button switch
Went to Thermador Website and purchased the part to be replaced.
Posted on Aug 02, 2009
Motor won't start. The reset button won'the push is and reset. I can push it in, but it's really loose and isn'the working right. Have I blown the motor?
More likely that it is a bad door switch. Push the door switch in manually and see if you can hear/feel a clicking sound. If this switch is not made (closed) the dryer motor will not start. If you burned up your dryer motor (unlikely) you would have smelled those burned motor windings! Hopefully as simple as replacing the door switch.
Feb 13, 2017 | Dryers
The inside lights wont come on
Hello Misti;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, which is located on the upper inside wall of your fresh food section. So, I can only be general.
Both lights in your refrigerator and freezer?
That is unusual.
Normally it is a burned out push button light switch. That just pops out using a butter knife for replacement. But to have both go at the same time?
The light switch goes to direct power and is not tied in with the control board. You have a short or a burned wire. They may be tied in together.
Unplug your refrigerator and carefully pop out each push button switch and inspect the contacts. Some units have the push button contacts at the top in a cover. Some have a magnetic contact which is built into the casing.
Also, you can not use household bulbs in a refrigerator, they eventually will fail. The are special ones for the freezer and special ones for the fresh food section
Mar 25, 2015 | Refrigerators
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Start button is stuck
The start button is a two position switch. Push in half way and the lights turn off so more power goes to the starter. Push all the way and the solenoid clicks engaging the starter. Some times you can carefully take apart , clean , and reassemble your switch(may just be a loose screw. Worst case scenario go to the Honda dealer or local salvage and get a switch assembly and replace the non working one.
Jun 16, 2010 | 2004 Honda VTX 1300
How do I set the time of day for an Intermatic ss7c timer
How to set or change the clock
1. Remove the clear cover/switch.
2. Push and release MODE button until CLK is displayed (2a).
3. Push and release DAY button until correct day of week is displayed (3a).
4. Push and release H+ button until hour and AM/PM are correct (4a).
5. Push and release M+ button until minutes are correct (5a).
6. Push and release MODE button to choose AUTO,AUTO RAND or MAN.
7. Replace clear cover/switch.
8. Push and release clear cover/switch to switch load ON or OFF if
necessary.
PM
DAY H+ M+
Oct 13, 2009 | Hardware & Accessories
I have a Hygena Built in fridge freezer and the freezer is defrosting and the fridge is not coming
hi try this On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale
Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
Step 4: Connect the new switch the same way the old one was connected.
Sep 13, 2008 | Refrigerators
Whirlpool built in fridge
hi On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale (instructions for using the VOM are given on page 19).
Sep 13, 2008 | Whirlpool Refrigerators
Thermador CVS30R Kitchen Hood Logo
251 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
