Question about Microsoft LifeCam NX-6000 Webcam
Blue screen shut down when webcam is plugged in USB port
Uninstall all webcam drivers, including the one that comes with webcam (LifeCam 1.2) and install most current driver from Micosoft website before plugging in NX-6000 webcam.
Posted on Aug 03, 2009
Laptop restarts after shutdown
This sounds like the On/Off program in the "Programs and Features" section of the computer. On newer computers, there is a feature called "On/Off", and what this does is it keeps power going to the USB ports on the computer so you can charge things and keep things plugged in. Sometimes, if you have certain things plugged into a USB port, and you shut down your computer, the USB ports will "wake" your computer up and turn it back on. Simple things like a wireless mouse will cause this, I know because I use a Logitech Trackball mouse and it's wireless. I had the same issue, and found out that simply flipping the switch on the mouse itself(turning it off), solved my problem. I would recommend either shutting the external devices off when you shut down, or just completely unplug everything from the USB ports(minus the keyboard).
Aug 26, 2016 | Dell Inspiron N7110 I17r-6434dbk...
Logitech QuickCam Deluxe for Notebooks webcam immediatelly shuts down my Compaq laptop as soon as it's plugged into the USB port.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 26, 2013 | Logitech QuickCam Deluxe for Notebooks
My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Jun 23, 2012 | Dell Latitude D410 Notebook
I have a Creative Live ! Optia AF Webcam. If i put the USB of the Webcam in the USB-Slot (1 of 4 USB-Slots and all tested), i get a Bluescreen Error and my Computer shuts down. Is my Webcam destroyed? The...
A bluescreen error is rarely a good sign, but sometimes it's fixable. Have you tried plugging the webcam into a different USB port? Also have you tried unplugging some unnecessary USB devices and then using the webcam? You may be draining too much power from the PSU with USB devices and the PC shuts down to prevent damage. Have you been able to test on a different computer to see if the problems happens there as well?
Mar 24, 2011 | Creative Labs WebCam Live!
When I plug my 500 GB "my passport" unit into the usb port, windows shuts down and the blue screen appears saying a problem has been detected.
  1. As always when oddities occur, run an anti-virus program scan and spy-ware scan.
  2. Make sure there is an available drive letter between D and H, if you have a multi-card reader, multiple CD drives, etc. then you may be pushing the drive too far down the alphabet to initialize.
  3. See if the drive will mount in safe mode, if it can then something is killing the device...run "msconfig" and use it to remove any TSR programs and services which you don't absolutely need in the system until the device can be initialized.
  4. If you have the option between a regular USB port and a USB 2.0 port, remember to setup the drive in the USB 2.0 port.
May 03, 2010 | Western Digital Passport WDXML800UE...
Try to turn on webcam,it comes on momentarily and then i get an on- screen message saying the cam is used in another application, and to shut down other applicaton and retry,
Webcam software has a habit of remaining hooked up to any previous application it was used in.
When you get this message re-boot the webcam software by unplugging it from the USB port for a few seconds.
Apr 19, 2010 | Logitech Quickcam Chat Webcam
My girlfriend got a dell inspirion mini 10 for christmas and we've been using it's webcam and if she doesn't have the power cable in the computer it runs fine, but when she plugs the power cable into the...
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Blue screen
Some usb devices are like this. The manufactures simply don't tell you that this can happen.
Your best bet is to boot the PC with the device connected and to shut it down before you unplug it. I know it isn't plug and play but this may be your only choice.
I used to have a phone that did this one in every ten times I connected it.
I would hold my breath each time I plugged it in :)
Hope this helps
Sep 20, 2009 | Evga nForce 680i SLI (122CKNF68)...
White screen.
If you are using a usb hub, connect the lifecam directly to one of the usb ports on your computer.
Apr 19, 2017 | Microsoft LifeCam VX-6000 (68C-00001)...
Problems with usb device
Can you please provide me some information from that Blue screen
(That Blue screen is known as BSOD - Blue Screen Of Death - As on that screen you dont have any OK / Cancel Button and you dont have any other option other that Restarting your system manually when BSOD appears thats why it is known as Blue Screen of Death -
Anyways the important information from that error screen is located in the Second Paragraph + Last paragraph where some Hex codes are written
I want that information
Because most probably this is NOT a virus problem but it is a Hardware problem with your USB port)
Jun 02, 2008 | Computers & Internet
Microsoft LifeCam NX-6000 Webcam Logo
217 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
