Question about Lexmark X1270 All-In-One InkJet Printer
Mine wont print in black even with a new cartridge,only prints in 3 colors but not black
Every one should forget lexmark and buy a Brother...they are the best
Posted on Sep 20, 2009
  • preston grant
    preston grant Feb 08, 2014
    i did buy a brother printer, it won't print
I put new cartridges color and black in printer. They are in the right places but it only prints black
New cartridges? When checking ink levels does it show FULL? Have you run thru the Maintenance solutions such as CHECK INK LEVELS CALIBRATE PRINTER-CLEAN PRINTHEAD-PRINT TEST PAGE ? But of course each model and brand is prob different . (Mine is A KODAK)Ive experienced this The solution for mine was certainly nothing technical. But it worked..the ink had apparently dried in the bottom of cartridge even though it was new) if you try this wear gloves it could get messy! Take an old saucer put a small amt very warm water on it just enough to reach the 'color holes' on bottom and set cartridge in it for a couple minutes.in just couple mins my ink started flowing.then I moved it close to rim of saucer out of water for a minute , tapping off any excess water, wiped off with paper towel reinserted and it was fine. Now this may not be the answer to your problem but it wont cost to try and it wont hurt the cartridge. First thing tho I would check INK LEVELS make sure printer recognizes the new cartridge
Dec 27, 2014 | Office Equipment & Supplies
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Im trying to print a black and white document but it wont let me print because my color cartridge is missing
The Lexmark X2600 requires both cartridges to have ink in them to continue printing, even if your printing in "black and white". To print true black, you actually use some of the color ink. , Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality issues.
Sep 22, 2011 | Lexmark X2600 InkJet Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Can i print black prints without refilling the color ink cartridges? my color cartridges are empty but the black is full. The printer wont let me print black and white files.
Not certain on that model of Brother but on mine I was able to get it to print by changing the settings in "Print Setup" If you change these so that it can only print in black and whiye, it won't look for the colour cartridge, like mine didn't
Jan 24, 2010 | Brother MFC-5440CN All-In-One InkJet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Ink cartridge replacement
I had the same problem, and after scouring around online for a few days, I learned that this is one of the biggest gripes about this printer. Basically, you're out of luck unless you replace EVERYTHING, even though you only want to print black (nuts, isn't it?). So I went out and bought all new color cartridges, and it STILL won't print. I think it's just a bad printer all around. :(
Sep 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
125 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
