Question about NetGear WGR614 Wireless Router
One of the PC's on the network cannot access the internet. I replaced the cat5e cable and still no access. The messgae reads "no connection to the internet is currently available". The other PC connects fine through the router.
    Problem Solver:
  • 6 Answers
Did it ever work before? Are you running DHCP? What is the IP address on the other one that works?
Posted on Aug 01, 2009
Network cable not properly plugged in or may be broken
which OS do you have? XP, Vista, 7, etc. you must have a wireless adapter in your PC to use wireless and it must be enabled.
if not wireless, then you must have an ethernet slot with cable(CAT5) inserted from internet modem/router. if you have a laptop then you have wireless available. there is a key on keyboard to turn wireless on. you have to have your Network assigned to the wireless internet provider too. if you have cable(cat5) connected to a modem or router/modem connection, and you see an ethernet icon in your lower right corner window(looks like a little computer display), then you have an ethernet connection. if not then either the cable is bad or the modem/router is not producing a connection to pc. thats alot i know but i have little knowledge about your internet connection on your pc. you have not given that to me to use
Apr 18, 2014 | Microsoft Computers & Internet
Acer aspire 5335 connects to wireless internet, but not with eathernet cat5 cable?? thanks
Make sure the Network Connection for the LAN is not disabled. Click Start/Control Panel and look for the Network Connections. Make sure the Network Connection for the LAN is not disabled. if it is disabled, right click on it and select enable.
Also the port could be bad on the computer. If it does not light up when you put the cable in the port might be damaged.
May 01, 2012 | Computers & Internet
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
Need to know what i need to connect my prewired home (with cat5 cable running from box in garage to jacks in 4 rooms) to the internet. currently just have cable modem in office.
You would need a 4 - 8 port router... with a wire going to each Jack... and these would plug into the Router ports, The router plugs into the Modem. You have to put the Ethernet plugs on each end of the Cat5 cable. Then you setup your network. But if you have a wireless router you simply need each PC WiFi enabled, IE: A wireless card in each PC, that way you do NOT need Cat5. Then each PC, simply connects to the Router/Modem.
Mar 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Will not connect to the internet wired or wireless
Unplug your power from the modem first and after that unplug your power to your router, disconnect all your cat5 cables and wait for at least 20 secs. After 20 secs or so go ahead and plug your power back to your modem and wait until all the flashing green lights are solid and that the link light starts blinking. After that plug in your Routers power (You can also reboot your PC while this is going on) . Wait until all blinking lights becomes steady then re-connect your cat5 from the modem to your routers uplink and last the cat5 cable from the router to your PC. If you'd rather not test the direct connection then go ahead and switch your wireless on.
Your wireless connection properties on your PC under "Internet Protocol TCP/IP" should be set to "Obtain IP address automatically" and that "Obtain DNS server address automatically" should also be set. Your routers should, if not already, be set to automatic DHCP. Make sure that on your Device Manager > Network Adapters that your wireless network adapter is not disabled and that it has the correct driver (yellow exclamation on it indicates it needs correct driver). You should disable your integrated ethernet LAN card if you have enabled your wireless Network Adapter to avoid conflict.
On your Wireless Network Connection properties under "Wireless Network" tab go to "Preferred networks" and highlight your wireless network name (SSID) . After highlighting click on the "Advanced" button and select "Access Point (infrastructure only) networks only"
Jan 23, 2009 | Toshiba Satellite L25-S119 Notebook
My network says that it can't find the internal wireless adapter
You may have to reboot your PC and try to connect again.
If you have "Viewed all available networks" and tried to connect to your Wireless network but cannot what kind of error message are you getting ?
To quickly find out if you have Internet Connectivity coming in at all from your Internet Service Provider turn off your wireless switch on your laptop and try to connect a cat5 directly from your PC ( connect cat5 cable to what looks like a slightly larger telephone jack on the side or back of your laptop) to the back of your router and see if you browse the internet. You may have to reset your router (unplug and plug)
Jan 10, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Connecting Cat5e cable to BT 78A junction box
You can get this device to help you.
http://www.run-it-direct.co.uk/run-IT-direct%20Price%20List.pdf
I believe it is on the 8th page.
Oct 08, 2008 | Computers & Internet
I've installed my wireless router, modelwrt54g2v1, and the yellow ethernet cable is still connected to my laptop, once I remove it I have no connection?
The yellow cable (CAT5) is giving you your internet connection
you will need to follow some steps:
1) Access the routers GUI (usualy by going to a web-page in your Internet explorer EG 192.168.0.1 check the manual)
2) make sure that wireless is enabled on the router + DHCP is enabled
3) at this stage set wireless security here as well (to stop unwanted use of your broadband and people hacking your PC)
4) make sure that the laptop wireless is switched on, sometimes there is both a physical on/off switch and a software/keyboard enable/disable button, disconnect the Yellow network cable
5) go to control panel:network connections
6) right click on the wireless connections icon and then view available wireless networks
7) if you see your network then highlight it and click connect
8) enter the security password (if any) which you set in step3 above.
let me know how you get on
Aug 29, 2008 | Computers & Internet
Network cable stopped being recognized
rj45 (cat5) sockets have 8 internal tensioned wire prongs, (six are used for cat5 ethernet)
use weakens the tension and they can be dislodged sideways vertically or disconnected from the internal cabling. Likewise solder connnections to the motherboard fail.
a possible fix is to power down the pc, and with a jewellers screwdriver ensure that all the internal wires are present, straight, aligned, and protruding across the opening.
If there are missing wires(broken) then the rj45 socket shoould be replaced at your local pc store, (not walmart)a796c91.jpg
Jun 28, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
NetGear WGR614 Wireless Router Logo
44 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
