Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi Projection TV problem
On all the inputs but HD input I see vertical stripes spaced ~2" apart. They only disappear when the input video signal comes in from the XBOX 360 to the DTV input (on RGB with 480p) and only when the format is set to Standard. With other formats (Expand, narrow, etc) the stripes reappear.
Can you help?
Thanks,
Adam P.
  • grooves May 04, 2008
    on all the inputs there are vertical stripes about 2 inches apart and they don't go away for a half hour or more
  • 116 Answers
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Posted on Mar 06, 2008
I just started seeing red lines going across screen and picture has ghost now. Is lamp going bad? Red line is a somewhat u-shape about 1/4 from top of screen.
Posted on Mar 15, 2008
2 Suggested Answers
premtech
  • 934 Answers
SOURCE: Mitsubishi WS-65809 65 in Projection TV problem with vertical stripes
I'm fairly sure that the 2hdw board is the culprit here. The 2hdw pwb is Mitsubishi original p/n# 935c966001 which has since been substituted to p/n#935c966002 and costs roughly $420.00 dollars plus shipping.
It's a common failure in these units, but it's not a difficult repair for a reputable shop..
Another alternative is to have ashop pull that board and send it in to PTS Electronics for rebuild. That might save about $100.00 dollars.
Please don't rate me badly for the bad news.
Good Luck!
Bill
Posted on Nov 25, 2007
Mitsubishi CS-35301 35 in. rear projection. can't switch inputs
if you have s video connected some tvs wont allow you to use input 1 or 2.disconnect s video cable and try that other wise you got something wrong.
Apr 25, 2010 | Mitsubishi CS-35305 TV
Display problem with Mitsubishi Projection TV
Do you mean vettical stripes across the whole screen
or bands on each side of the screen lik this
http://reviews.cnet.com/4352-12658_7-6544387.html
If this is what you mean then your users manual has
the solution on pages 33-36 if you dont have the manual
it can be downloaded here http://www.tacp.com/tacpassets-images/models/50hp66/docs/50hp66_om_e.pdf
Nov 22, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Green vertical bars on a Samsung projection
That is a problem with your main board - some of your inputs work fine and another is bogus. The tv input is not working because there could be a defect in your tuner. If you have cable try a different input for the signal.from the box. If you are using OTA, then use an external HD OTA tuner to feed your set.
Sep 09, 2017 | Samsung HLR5067WX 50" Rear Projection HDTV
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Good Luck!
Bill
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
306 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
