SOURCE: BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
SOURCE: How to adjust door hinges on fridge
on the door thats sagging on top of the of the door is a cap some have a screw holding it....if not use a screwdriver at the back of the cover and pop it up then you have small bolts some have 2 but most have 3 just loosen up but no need to remove then pull towards the hinge to see it move again move to the to where level you can place something in the gap between the door or have someone hold the door in place then reverse order to complete
Testimonial: "Thank you. I just fixed the problem singlehandedly with yor helpful instructions!"
SOURCE: Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
SOURCE: How do you repace the door hing on a AAA140 Hoover
should not need to as the 2 screws holding the hinge to the frontplate of the machine goes into a threaded nut welded to the panel (a torx 30 or 40 bit is needed).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Testimonial: "Thankyou very much. Didn't know it came off so easy. It worked like a dream"
SOURCE: need to replace upper door hinge on 1997 dodge ram
Contact LMC Truck Part's and order a dodge ram catalog, They have a repair kit for the 1997 Dodge ram hing .
Thank you for your post, friend!
I understand that you're asking how to align the front door of your Frigidaire washer. I would recommend having a professional come out to your appliance, some of these intricate parts do require precision and patience. I hope this is helpful. -Matt
