Question about Dell Inspiron E1705 Notebook
Dell Inspiron E1705 will not power on
Video card was going out with geen dots and lines on screen.. Clean computer parts and cleaned all fans, CPU & GPU, and added new thermal paste.. Now computer will not power on... Rechecked all connections and cables... Reseated RAM chips.
When power button pressed green power light comes on for 3 seconds nothing else... Do you think it might have been a faulty mainboard?
Thanks in advance...
    Scholar:
  • 177 Answers
Yeah, looks like a bad mainboard.
Posted on Aug 01, 2009
Dell Studio xps 8100: Motherboard changed, when booting up I get to the f2/f12 screen with have a progress bar and computer turns off?
So picture guy, LOL
Most all boards have two power plugs from PSU, (power supply unit)
a 20 or 24pin and a 4 or 8pin.
The rest from PSU are for hardware, except if you have any video cards in pci-e slots, but they are not truly part of the motherboard they are addon.
Then from the case you have power button, reset, pled,hdled.
Sata ports on mobo, cpu fan, addon fans, DVD rom.
Front panel audio.
So now you have taken one memory stick and entered the BIOS, then tried each one.
You need to check each stick.
Now you put in your hdd erase disk, boot from it and you're going to erase your hdd so it's all clean for a fresh install.
Now you throw in the windows disk and you boot from it to install windows.
Right !!!
Apr 16, 2013 | Dell Studio Xps 8100 Desktop Computer...
Display issues, definate hardware problem
Hi there!
Yes you might be right, it can be the video card.
You can try to run some test first to make sure.
First, if you have an external monitor plug it in the computer then check if the horizontal lines
are still there, if it is then you'll definitely need to replace the video card, but if not then you might wanna check the LCD.
If you don't have an external monitor try to check this things first.
1. Check LCD if it is the one causing the problem.
Run the LCD test by pressing D + POWER while the computer is off,. if it is not working try to run
the diagnostics in the computer the it will flash colored
bars then say no to it it will test the LCD,
If you don't see the horizontal lines on the LCD test
then its a video card problem and if you see it its a LCD problem.
Just want to give you a heads up, you may be including the motherboard for the replacement
because your video card is integrated to it and replacing the fan heatsink can help resolve the problem.
Mar 24, 2010 | Dell Inspiron 1420 Laptop
Dell Inspiron E1705: Getting lines/blocks of color on monitor
From a power off state, press the Fn key and the power button, this will run the BIST which is a diagnostic on the LCD, if you get screens of solid colors.
From what you describe, I'd suspect the video card which could be the motherboard or memory, try the memory modules one at a time, see if the issue only occurs with one module
Feb 28, 2010 | Dell Inspiron E1705 Notebook
Fried Video Card
if you "fried" the video card you wouldn't get anything on the screen. Most Likely the wrong driver got installed or you need to check video properties to set video screen size and drivers installed.
Happens when installing updated video drivers.
Note: MS Update has installed incorrect drivers because thay were "NEW" but were incompatible with the video card on my systems before. Had to unistall "NEW" and reinstall "OLD".
Feb 02, 2010 | Dell Inspiron E1705 Notebook
I have a Dell Inspiron E1705 that seizes up.
sounds like your hard drive is about to take a dump or cpu is not cooling good and she is over heating mite get a can of air and blow your fan area out mite be stopped up by some dust try this and see if it helps....
Dec 10, 2009 | Dell Inspiron E1705 Notebook
256 MB Nvidia GeForce Go 7800 for Inspiron 9400/E1705 Card Failu
Both solutions are wrong. The Dell Inspiron 9400/1705 is a laptop. If you buy a Nvidia GeForce Go 7800 for this laptop, you need to buy a Dell Inspiron 9400/E1705 motherboard for a discrete video card. The integrated video is a Intel Graphics Media Accelerator 950. The integrated video has the video chipset on the motherboard and the discrete video (GeForce Go 7800) has the video chipset on the video card.
Jul 09, 2009 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
Video internal and external vidoe out put is vertical lines in groups but other wize it works
i found that the nvida model p469 video card hand ben over heated and the heat sink was pluged with lots of dust it suffered damaged in the video card due to over heating. i lust need to buy a new video card dell said this model of laptop has lots of over heating isues with the video cards so the real sultion is to get a can of air blast and clean the cpu fan and the video fan every 30-45 days to prevent it from geting gloged up with dust . this littel lesson just cost me a waping $399.00 just for the video card. the only real question is why did dell not have the bios turn off the coumputer when it was over heating it would have prevented damaged.
May 17, 2009 | Dell Inspiron E1705 Notebook
BUILT-IN MIC ON DELL
Yes, it does, 'evidence' below.
Specs of the Dell Inspiron e1705 Being Reviewed:
  • Processor: Intel T2500 2.0GHz Core Duo
  • Motherboard Chipset: Intel Calistoga i945GM/PM
  • Hard Drive: 100GB 7200RPM SATA (Hitachi TraveStar)
  • Memory/RAM: 1GB (1,024MB) Dual Channel DDR2 SDRAM (667MHz)
  • Screen: 17.0" UXGA TrueLife (1900 x 1200 pixel resolution glossy screen)
  • Graphics: nVidia GeForce Go 7800 256MB
  • Optical Drive: DVD +/-RW with DL DVD+R write capacity
  • Battery: 9-cell (standard size 6-cell, 9-cell extended life optional)
  • Wireless: Intel PRO/Wireless 3945ABG (802.11 a/b/g)
  • User Input: Touchpad
  • Dimensions: 15.5" x 11.3" x 1.6" (Width x Depth x Height)
  • TV Tuner: Optional external USB TV Tuner with remote control upgrade for $104
  • Weight: 8.1 lbs
  • Ports:
    • 6 USB 2.0 ports
    • IEEE 1394 (FireWire)
    • Digital Video Interface (DVI-D)
    • VGA out (monitor out)
    • S-Video Out
    • RJ-45 (Ethernet LAN)
    • RJ-11 (56-Kbps Modem)
    • Audio line out for headphone/speakers
    • Microphone
  • Slots:
    • 5-in-1 Multi Card Reader (MS, MS Pro, SD, MMC, xD)
    • 1 ExpressCard 54 slot
  • Buttons:
    • Power on/off
    • Volume up/down/mute (3 buttons)
    • Media buttons (play, forward, back, stop)
    • Battery charge test button
    • Battery lock and release
May 03, 2009 | Dell Inspiron E1705 Notebook
I have Dell laptop inspiron 630m. I formated the laptop then the display driver is missing. Its showing all the things except its display got more wider
just check your video card model, then go online to download the video card driver.
in case you have a build-in-video card like intel .....somethings, just go back dell.com and check your model , and download the video card driver.
Jan 14, 2009 | Dell Inspiron 630M Notebook
Dell Inspiron 8100 laptop cooling fans
All fans for cooling cpu plug into a small 2 or 3 pin socket usually white on the motherboard near to the heatsink your fan should have the lead coming from it
fans for video card sometimes takes the power from card or connect to board same as cpu fan but near video card
Aug 08, 2008 | Dell (6F858) Cooling Fan
Dell Inspiron E1705 Notebook Logo
364 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
