Question about Fujifilm WL-FX9B 0.79x Wide Conversion Lens (Black) for Finepix Digital Cameras (Includes Lens ...
Wide Coversion Lens
What exactly does a Wide Conversion lens do? How much wider picture do I get with a 0.7X wide conversion lens? Does this mean I get 70% more view?
Re: Wide Coversion Lens - Fujifilm WL-FX9B 0.79x Wide Conversion Lens (Black) for Finepix Digital Cameras (Includes Lens ......
Posted on Apr 02, 2008
0 characters
3 Points
How to remove moisture from a sony wide conversion lens
Put it in some Rice in a plastic bag, let sit for a cupole of days!!
Jun 24, 2014 | Sony 58mm 2x Telephoto Conversion Lens For...
What adapter do i need to make a vivitar 52MM wide angle lens work with a Nikon D-3000 with a 18-135MM lens?
I'm afraid this will not work.
The filter size from the Nikon is 67 mm. and your vivvitar had a 52 mm tread. The step down convertor from 67 to 52 will block to much to use the wide-angle convertor.
I think you still will see a wider part in the centre of the frame, but in the end, the vignetting that takes place, will leave you with only a part of the picture to use. What stays will be smaller than what you pick up with the lens in the 18 mm setting.
Just try what you see, when you just hold the vivitar in front of the lens and shoot a picture. Take care you don't scratch the front lens of your 18-135. put a cheap UV filter, when you want to test.
See you only have a circular picture with this test.
I have a 12-24 lens and only use it once a year, so if you don't have a special purpose for a wide angle, don't bother buying one.
May 09, 2014 | Vivitar Camera Lenses
How do you delete photos on finepixA500 digital camera
if you can't find the option to delete them on your camera, when you have uploaded them to your computer windows will give you the option to delete them.thats what i use to delete pics from camera.hope this helps
Apr 19, 2010 | Fujifilm WL-FX9B 0.79x Wide Conversion...
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Can't delete photos
Turn the camera off and remove the memory card. Turn the camera back on and now you should be able to remove the pictures stored in the internal memory.
Dec 03, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Lens for a finepix s5600
I need to know if my wide angle lens will fit other camera brands
Nov 18, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
The lens is cloudy
Well the lens gets mositure even when it's in the bag, it's because of the humidity.
what I usually do when it happens is I put it in a hot dry area, like in the sun or somthing like that so the water can vaporize.
Nov 11, 2008 | Sony 0.7x Wide Conversion Lens for...
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fujifilm A345 camera
does this carmea have a zoom on it]
Jan 19, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Camera Lenses Logo
91 people viewed this question
Top Fuji Camera Lenses Experts
Bart Pulverman
Are you a Fuji Camera Lens Expert? Answer questions, earn points and help others
