Question about Lexicon Omega Pro Studio External Sound System
Does sonar 6 work with lexicon omega interface? If so are there any reasons why it is not registering a signal on the interface.
5 Suggested Answers
SOURCE: Blue Screen of Death when running MIDI input to Lexicon Omega
I tried the above - works perfect!
Thanx lumps...
Thomas
Posted on Feb 07, 2008
  • 34 Answers
SOURCE: Cubase and Lexicon Omega
Yep that's Vista for you! Try microsoft. com for a patch or the product's website.
Posted on Mar 16, 2008
  • 3 Answers
SOURCE: Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Posted on Aug 09, 2008
  • 46 Answers
Install Windows Vista service pack 1.
Thanks
Posted on Aug 28, 2008
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
Aug 09, 2008 | Lexicon Omega Pro Studio External Sound...
Mar 16, 2008 | Lexicon Omega Desktop Recording Studio...
Device is unrecognised always day per day
I've been struggling with this issue for about a week. My unit was locking up increasingly more often.
Two things I've noticed about my Lexicon interface:
1. Seems to be excessively hot.
2. The unit is not vented.
Yesterday, after reading a comment about the solder possibly being the problem, losing conductivity as the units warms up. I decided to run my Lexicon with the plastic case removed.
Since removing the the case, i have only had one instance where the sound stopped working, which i believe was a problem with Cubase in that instance.
I'm not sure if removing the case to keep the unit cooler is the solution. I may have improved a connection somewhere in the process of opening up the unit.
I can say that I went from getting a "new hardware found" message every two minutes to having virtually no problems since removing the case.
My next step will be to drill about 50 holes in the case to vent it before attempting to use the case again.
Best of luck to ya!!!
Nov 06, 2007 | Lexicon Omega Pro Studio External Sound...
Lexicon Omega Pro Studio External Sound System Logo
218 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
