Question about HTC Touch Cellular Phone
G1 touch screen stop working cant use the phone without the touchscreen
    Brigadier General:
  • 7,752 Answers
The screen needs to be replaced take it to a mobile service center and have that done there.
Posted on Aug 01, 2009
All of a sudden my touchscreen has stopped working, so |I can't unlock my phone. It boots up ok, it's rang, reminders have gone off, texts have been received, but I can't unlock the phone as the touch...
You cant fix it. This has happened to me before and several other people, your phone is defective, if it is within the first year of purchase HTC or Tmobile will gladly replace it for you as they did with mine. I have tried even doing a factory restore and it appears to be a hardware problem so it is out of your hands. Sorry I wish I had a better answer for you.
Sep 01, 2010 | HTC G1
G1 got little wet but it dried out and screen shows all but now triangle and cant get touchscreen to work....what do i do?
If it got wet it might still be wet from the inside and that is why your touch screen wont work, You would need to open it and clean it from inside. Or it could have a bad digitizer and that is a second reason why the touch screen wouldnt work. You can try doing a hard reset if you says it just shows a triangle on the screen.
Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle
Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Jun 15, 2010 | HTC G1
Touchscreen not working properly
I agree. I'm on my 2nd G1 right now because my first one had touch screen problems. But the problems only started after I started using a different charger (it's been so long I can't remember whether it was just my blackberry mini usb charger, or whether I charged it from my computer; I think it was the computer). However, once it started spazing out it wouldn't stop, it was permanently damaged. So if your touch screen seems a bit finiky after charging with an odd power source, Stop ASAP or you risk permanent damage
May 14, 2010 | HTC G1
My g1 touch screen wont work
Hello so i have a G1 the screen stopped working. I cant accesess my contacts. I cant make a call. This is pissing me off please help me! This phone is really nice and straight just random problems popping up which really sucks!
Oct 02, 2009 | HTC G1
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
Jul 17, 2009 | LG Xenon GR500 Cell Phone
I have water damage on my G1 but it still works however the touch screen doesnt. i did a hard reset and unable to bypass the welcome screen without the touch screen is there a way to bypass it without the...
There is no way to bypass the touchscreen step of the setup process. I repair phones, including the T-Mobile G1. I can replace the screen for you if you would like for $60. Please email me at IGcomputerservices@gmail.com for more information.
Jul 14, 2009 | HTC G1
G1 TOUCHSCREEN
Hi there, You are lucky that it is on... try one thing.. put the fun under the sunlight for half an hour or may be 15 min if its too hot there and try it again...
if this will not work then try to open the phone if you can clean the top screen area and put it back (try at your own risk) and it will do..
Mar 23, 2009 | HTC G1 Smartphone
G1 touch screen not working
my workaround is to charge with a different power source, or stop charging. i think it's the power source. for me, the touchscreen goes crazy when i'm charging via usb with this old computer, but it's fine when i stop charging. it's probably an unclean power source messing with the capacitance sensor.
Nov 10, 2008 | HTC G1
Touch screen
You may have dust accumulation around the edges of your touchscreen, between the screen and the case. Try using a can of compressed air. Gently press down on the edges of the touchscreen to expose the gap between the screen and the case, and shoot the air in there. This worked for me when my Treo 600 touchscreen stopped responding.
May 23, 2007 | Palm Treo 600 Handheld
HTC Touch Cellular Phone Logo
122 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
