Question about Hotpoint Aquarius WMA42 Front Load Washer
Need to replace belt on VTD60 - Dont know how
Hello Hotpoint Guru,
Got a Hotpoint Acquarius VTD60 dryer. Had the problem of the drum not spinning. Removed the screws on the top and 1 side of the dryer and found that the belt had snapped and was lying on the base of the dryer. I have ordered a new one. I guess my question is - I have no idea on the orginal location of the belt ?. What do I put it around ?. Do I need to open the front of dryer as well. If you have any diagrams, it will go a long way
Your assistance will be greatly appreciated.
barkencoa
  • 3463 Answers
SOURCE: am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
Posted on Jun 03, 2009
barkencoa
  • 3463 Answers
SOURCE: drum is loose and banging on hotpoint aquarius wf541
This sounds like a classic case of main drum bearing or drum support failure, it is a major repair and not really a DIY repair, unless you are coversant with w/m's
It involves a complete strip down and in some cases it is neccessery to to have to replace the drum as well.
The cost of the parts involved is well in excess of £100.00,and it really is not an economical repair.
I think you would be better off buying a new washer.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
  • 5 Answers
SOURCE: hotpoint wd64 front load washer-dryer filter
if your hotpoint has no obvious filter its likely to be the type that has the filter built into the main exit hose from the drum to the pump. Clearing these is not as easy.Pull machine out and unplug it, on the rear there is a panel at the bottom which when removed you will see the pump where the exit hose attaches. From the pump to the drum is normally a wider black pipe and this contains the filter. removal of the pipe from the bottom of the drum is normally a jubilie clip but some have plastic clips that are easy to break. once you have dropped the pipe from the drum ( water goes everywhere ) you can then remove the white filter assembly which is like a shuttle **** with ping pong ball in it. clean out fully and make sure its all back together as before.
Posted on Sep 17, 2009
barkencoa
  • 3463 Answers
SOURCE: Belt fitting on a Hotpoint WMA46
Hi.
These belts are difficult to fit.
They appear to be too small, but they are in fact a stretch belt, so their is no adjustment provided on the motor itself.
The best way to do it is remove the back panel as you have done, remove the top cover also.
The with someone's assistance, tilt the washer away from you at the rear, getting someone to hold it for you.
Put the belt round the motor pulley first, and start feeding it round the drum pulley, slowing turning the pulley as you do so, the further you get it round, the tighter it will become.
Just keep going, and the belt will go on, watch you don't trap your fingers in the process. If it slips off, then start again.
Good luck
Please rate my solution.
Thankyou.
Posted on Jan 08, 2010
Rear bearing
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Feb 06, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Dryer clunking noise
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Jan 27, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
WIRE CONTROL PANEL
Could you please describe the problem you are having?
Oct 16, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Dryer making noises whilst in use.
all vtd range have bearing problems
Oct 15, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
I have a Hotpoint Aquarius Tumble Dryer VTD60, but drum will not turn!! Any suggestions.?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 07, 2011 | Dryers
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint Aquarius WMA42 Front Load Washer Logo
371 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
