Question about Ryobi Garden
How do I change string on my Ryobi TrimmerPlus 132r? I am unable to get the cartage off to replace the string. I have aligned the arrows but it will not pull apart
Send me $45.99 and I will give you the information in three easy lessons. But wait! I will even throw in an easy dvd and a twitter showing. All for the easy one time payment of $45.99.
Posted on Aug 02, 2009
How to install the string cartridge on Ryobi Connexion 24V trimmer?
unlock the string module (Arrow), turn the cassette and replace it. don't forget to lock, Don't break the edge with anything, otherwise the new module won't fit, attention to the spring!
May 15, 2015 | Ryobi Garden
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
Jul 10, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Husqvarna trimmer model # 128LD.I want to get a tiller attachment.Can you give me the model I need for my model?
If you have the 128LD from Lowe's, Tractor Supply or Sears you can use TrimmerPlus attachments, any MTD manufactured attachments should work.
http://www.trimmerplus.com
May 26, 2010 | Husqvarna Garden
How to restring 132r trimmer
Get a gater head for your trimmer. It has 4 easy to replace strings, that when broke off you can make up a new set with a pair of side cutters, or just replace 1,2, or 3, I put one on my homelite and it's the best thing i've seen since sliced bread.
Mar 30, 2010 | Ryobi Garden
Can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
Jul 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My ryobi weed eater line keeps getting sucked back in
If you need a manual for ryobi 132r, I found it here - http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=pSo&tbo=1&q=ryobi+132r+manual&aq=0&oq=ryobi+132r+m&aqi=g1
Click on the link above and it takes you to a google listing. The top link is a PDF of a 15 page manual so that's the one you'll want to click on. It'll automatically save it to your desktop.
May 29, 2009 | Ryobi Garden
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi 132r don't work
THE MOTOR HAS PUSHED BACK INTO THE INTERNAL HOUSING. YOU CAN DISASSEMBLE THE HOUSING AND FORCE THE ELECTRIC MOTOR TO IT ORIGINAL SET UP BUT OVER TIME THE MOTOR WILL KEEP MOVING BACK. THE COOLING FAN WILL BEGIN TO GRIND ON THE HOUSING. THE PLASTIC, HOLDING THE MOTOR IN PLACE,WILL BREAK DOWN AND PUSH AWAY FROM THE ATTACHMENTS.
Sep 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
245 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
