Question about Goldstar Dehumidifiers
Goldstar GHD30T7 dehumidifier dead. very little use.
GOldstar GHD30T7 dead circuit board or component?? power to board, but no power across the RY-COMP even though my ohm meter shows closed circuit! Am I missing something?? Thanks in advance for your help. Paul
  • 210 Answers
SOURCE: dehumidifier freezing up, is it the de-icer control? can it be replaced ?
Could be the tempurature of the room you have it in. Make sure it is not operating in a room below 65 degrees F or 18 C
Sgt 48
Posted on Jun 02, 2008
SOURCE: ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
Posted on Oct 01, 2008
memturbo
  • 226 Answers
SOURCE: icing on back of coils on dehumidifier
could be dirt coils or low freon either way needs to be checked
Posted on Mar 27, 2009
  • 4 Answers
SOURCE: Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
Posted on Jul 11, 2009
bobicehouse
  • 1524 Answers
SOURCE: Is it possible to recharge the refrigerant in the
This must be done by an EPA certified technician.
Posted on Apr 08, 2010
My Goldstar model GHD30T7 runs but the compressor does not kick in. How do I correct this?
ck your humidistat settings sometimes these get changed No one knows why ? 70%rh is considered normal
Oct 10, 2014 | Goldstar Dehumidifiers
My Goldstar Dehumidifier is not collecting water. There is no air coming out the back. I have cleaned the filter.
Hi, Sounds like the fan quit....could be the board or the fan motor ...check for power at the motor...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 21, 2011 | Goldstar Dehumidifiers
Dehumidifier keeps blowing circuit
The compressor is bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 12, 2010 | Goldstar DH304 Dehumidifier
NO POWER WHEN PLUGGED IN, NO DIGITAL READ OUTS
1) check power outlet
2) remover cabinet and check glass fuse on power supply board that power cord attaches to.
Jan 04, 2010 | Goldstar DH504EL Dehumidifier
Goldstar dehumidifier model # DH305
I had this problem on a similar model. There is a pressure switch the tank when full pushes in, sometimes mine would stick. A little graphite for key locks was my remedy. Had to clean it up some though. Good luck!
Jul 13, 2009 | Goldstar DH304 Dehumidifier
GHD30 dehumidifier completely dead
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Nov 01, 2008 | Goldstar DH504EL Dehumidifier
Sep 13, 2008 | Goldstar DH304 Dehumidifier
CIRCUIT BOARD
I've replaced mine twice.  water pools under the board and shorts it out.  I raised the mounting points this time around.  I found the board at Appliance Parts 866-312-3498
Aug 13, 2008 | Maytag M7DH65B2A Dehumidifier
Dehumidifiers Logo
259 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
