Question about Oreck Vacuums
I have an oreck steam o matic. I get water when I
I have an oreck steam o matic. I get water when I switch it to rinse but I do not get shampoo when I switch it to shampoo.
5 Suggested Answers
  • 294 Answers
SOURCE: water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Posted on Mar 01, 2009
  • 29 Answers
SOURCE: Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
Posted on May 29, 2009
  • 21 Answers
SOURCE: Oreck rins a matic water drawing in..but not
What you may have is blockage inside the vacuum part of the unit or there is air getting in the top or sides of the receptical. See if you can gently get the receptical apart for cleaning. There may be pieces of carpet and /or hair or some obstical. This is if the vacume moter is working. IT may just be a simple thing That requies one or two screws to get the cover off.
Posted on Jul 25, 2009
sparktgo
  • 68 Answers
SOURCE: need manual for steemer
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/XLS465.pdf
Posted on Oct 12, 2009
Can I add vinegar to the water and steam clean laminate flooring?
Unless Shark says water only I don't think that would be a problem. All the vinegar will do is remove any grease on the floor and perhaps remove some bad odor. I rinse my hair with vinegar water every day after shampoo and conditioner. Only then do I consider my baby fine hair clean!
Jun 07, 2015 | Shark Steam Mop S3202 Floor Cleaner
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
XLS 700 manual
The User's Guide for the Oreck Rinse-A-Matic Steemer XLS 700 can be found online here:
http://www.oreck.com/PUG/XLS700.pdf
Thak you for using FixYa!
Oct 22, 2011 | Vacuums
I need a manual for Oreck Rinse-A-Matic (how to operatethis produce)
Go to Oreck.com. You can find the user manuals for all of their products there.
Oct 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
My oreck rinse-o-matic vac keep shutting off while i'm cleaning. I cleaned the water out and added new, I checked to see if anything was jammed up at bottom. It keep shutting off??
I had the same problem...kept pushing the reset button on the plug, but continued to shut off. Took it to my local electrician, who removed the plug w/reset and replaced it with a regular plug...works fine now. Must've been a short in the reset part...sometimes simpler is better! Cost me $7.00, lots cheaper than a new machine or the $100 repaire quote from oreck!
Mar 18, 2011 | Oreck Vacuums
F7210-900 Steam Vac. will not put out water when switch is in wash position but it will put out water when the rinse position
There are two electrical solenoids inside the hood assembly. One opens to dispense rinse water, and the other dispenses the soap and water solution. It is likely that the soap and water solenoid has failed and will require replacement. A "work around" fix for this is to mix the soap solution in the clear water tank ( 5 oz. of shampoo per gallon of water ), and shampoo that way until the solenoid can be replaced.
Mar 15, 2011 | Hoover Vacuums
Need manual for steemer manf by Oreck Rinse a matic
Oct 12, 2009 | Oreck XLS465A Upright Vacuum
Does it matter what kind of cleaner I use on the Deep Cleaner Model F5821
Yes it does matter which cleaning solution that you use in your steam cleaner. If you use the wrong cleaning solution it may cause problems with the cleaning solution dispensary system. Different steam cleaners use different cleaning solutions. You should always use the steam cleaner solution for your specific cleaner. I have learned this the hard (and expensive) way.
Hard to recommend this but it will work in a pinch. You can use a small amount of liquid laundry detergent diluted with hot water (about 2 table spoons to a gallon) as a stand in for the real deal. DO NOT put the laundry soap solution into the cleaning solution reservoir (the wax content will clog the soap dispensary system). Lightly apply to the area to be shampooed (do not soak). I have used a plastic coffee can with holes poked in the lid like a watering can to apply the soap solution. Use the shampooer to do the scrubbing and remove soapy water from the shampooed area. Fill your soap reservoir with clean hot water. The laundry soap does most of its job during the rinse. Go over the shampooed area with the shampooer moderately soaking the shampooed area to with the hot rinse water. Remove as much of the rinse water as possible. Liquid laundry soap has a high wax content (makes your cloths soft) and if it is not rinsed thoroughly after it is dry the remaining wax will attract dirt faster than the surrounding areas. Other than that it works for a good stand in for the proper detergent in a pinch. As a bonus it smells great.
From what I understand as unorthodox as it is, it works well in small doses, and I don't believe that it causes any damage to the other parts of the steam cleaner as steam cleaners survive drawing up worse things into them than laundry soap.
I hope that you find this helpful
Good Luck!
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water and shampoo run out with the trigger in the off position
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Vacuums Logo
96 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
