Question about Car Audio & Video
The Radio is on, but the sound has left the building.
I have a 1996 Mercury Grand Marquis.
My problem is the radio is on but the speakers don't work. once in a while if you go over a bump the sound will work for a short time, but that about it. I looked up the stereo wiring on line. Do I follow the wires from the radio to find the problem? What do you recommend?
  • 97 Answers
Ok more than likely u either dont have it grounded good enough or your speakers arnt hooked up good enough from each speaker follow that wire to make sure there hooked up good and also if there aftermarket use black electric tape and your ground wire is the black one make sure it is grounded good to a metal part on your car please let me know if this helps thanks
Posted on Aug 02, 2009
I need a radio color diagram for a 1996 jeep grand cherokee
1996 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Red/Gray
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Orange
Car Radio Antenna Trigger Wire: Green/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Sep 18, 2016 | 1996 Jeep Grand Cherokee
I have a 93 Grand Marquis LS,my radio just stopped emitting sound from all speakers. I have power, the green light shows on the radio face. What can it be something even I can fix I hope.
There may be more than one fuse behind the radio. I have 2, one for the display and one for the output section. It is possible the second of those has blown . To check you will need to access the
wiring behind the radio underneath the dqshboard
Jun 17, 2015 | 1993 Mercury Grand Marquis
Radio on no sound grand marquis
Check for radio fuse blown...under the dash, near the driver's left leg when seated in the car.
Oct 06, 2014 | 1999 Mercury Grand Marquis
Radio on no sound 99 grand marquis
did anyone one behind dash recently...sounds like speaker plug in disconnected from back of radio
1996 Mercury Grand Marquis wipers don't work. I changed the motor and the fuse isn't blown
You need to take the plastic cowls off that cover the wiper arm linkage and wiper transmission to inspect it...cowl is held on with 3 Phillips screws near windshield and some one inch wide metal clips, take off the gasket that fits on top. If both are not working check the transmission where linkages attach, if one wiper blade is not working it is usually the drivers side where the nylon bushing that forns a ball/socket sort of connection fails due to build up of debris and the rusting of parts that follows, let me know if this helps.
Dec 17, 2012 | 1993 Mercury Grand Marquis
What fuse amp in a Grand Mercury Marquis is for the radio (I don't own a manual)?
Yes, That would be a 5amp fuse. Located in number 13 fuse slot under drivers side dash. Watch your head. chaz.
Sep 04, 2011 | 2003 Mercury Grand Marquis
2003 Mercury Grand Marquis GS Radio just stopped working, but the CD player still works fine. I checked the (2?) fuses to the radio and they were o.k. What could be causing my problem? Thanks for any...
This is a common problem with this radio. I purchased a used 2003 Grand Marquis and the radio stopped working after a few days. I checked all the usual problems such as faulty antenna and connections. I then looked on line and many others have the same problem with this radio. The only advice is to purchase a used radio from salvage yard the same as the one you have now or you can also go with a good aftermarket radio for around the same price as you are going to pay for a used radio. A used radio would require just removing the radio which is a snap, and then plugging in the replacement radio using the same connections. An after market radio will require adapters and splicing wires. I chose putting in an aftermarket JVC radio and I really enjoy the sound and being able to play cd/mp3's and my ipod through the radio.
Feb 19, 2011 | 2003 Mercury Grand Marquis
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Radio wiring diagram needed
This is the only thing I could find, it is from a car audio site, hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Aug 29, 2008 | 1983 Mercury Grand Marquis
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
