Question about Symphonic SL260A S-VHS VCR
A tape was stuck, As I tried to get it out the
A tape was stuck, As I tried to get it out the power shut off and the 'tape in' light started to blink. I opened it and got the tape out, but now whenever I turn it on the vcr attempts to start, but turns off and has the 'tape in' light continue to blink.
  • 188 Answers
I geuss the timing of the deck is off.Realignment wil be needed.
Posted on Aug 04, 2009
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
My daughter just had a problem with her Philips tv. It has a built-in vhs player on it, and when she put in a tape, the tv started turning off. I turned it on and got a blue screen that says 't-eject'. I...
It is possible that the Tape mechanism is struck and so is shutting off the power to the unit. Since the power is shared it is possible that the cut off to the set is due to the error in the VHS player.
So in this case you will need to remove the VCR and get the entangled or the stuck up cassette from the player so as to reset the error. Also if there is a mechanical issue to the player must be checked.
Mar 18, 2011 | Televison & Video
I have a tape stuck in my drive and I can't eject it either on the hardware or using back up exec. The folloing lights are on Green power is on, orange status is on, and red error is flashing Any ideas how...
The only option for you is to remove the tape drive from your server, open it, and manually eject the tape that is stuck. This is not easy to do. Maybe it would be better if you remove the tape drive from the server and take it to a repair centre.
Oct 26, 2009 | Dell Computers & Internet
Tape is stuck in the vcr and when you turn on the power it turns the tape about 10 seconds and then shuts off the power.
if the tape has snagged inside, the only way to get it out is to take the top of the vcr off and manually remove it. very simple procedure. only use your fingers and not anything sharp. have you tried rewinding the tape (from STOP mode) sometimes tapes can end up being wound very tight which would have the same effect. if you can rewind do so, then fast forward until tape stops, repeat this a few times this should loosen the tape.
Sep 21, 2008 | Televison & Video
Reinsert cassette
I've been researching this for hours. I have the same problem. Took it to a repair shop today that would charge me $250 to replace the whole tape mechanism. Finally, I tried the whack trick. I gave the camera a good firm smack on the right side, and voila, now it works! I'm going to tranfer everything to DVD ASAP!
Jul 10, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Tape stuck in an Emerson Model EWV401 VCR
take it to someone who has experience in removing stuck VCR tapes or you will be paying a lot more for a new VCR. They won't charge you much....IF they even charge you.
Apr 04, 2008 | Televison & Video
Emerson ewd2203 video/dvd combo
Do you know why the tape was stuck? How did you get it out? On most vcr's there's a mode switch connected to the mechanics of the vcr. If the mode switch isn't in stop position, the unit will try to get it there and shut off if it can't. Bad belts, bad idler wheel, dirty mode switch, mechanical timing off (maybe due to forcing a stuck tape out?)... all these can cause this.
Geno
Feb 27, 2008 | Emerson EWD2203 DVD Player/VCR
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
VCR
you have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Oct 17, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Symphonic SL260A S-VHS VCR Logo
164 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
