Question about Garden
WHEN THE ENGINE GETS HOT, THE ENGINE SHUTS OFF. THIS HAPPENS AFTER ABOUT 30 MINUTES, THEN EVERY 10 MINUTES.
    President:
  • 1,714 Answers
Check all connections on the ECM (engine control module). Something is loose and heat expansion is affecting it.
Posted on Aug 01, 2009
John deere X720 mower ceases to operate the about 2 minutes later engine shuts off after it gets hot
sounds like engine is super heating because of bad valves do a compression test make sure you have 100 lbs on the cylinder if not do a valve job but while its open check the play in the piston by moving it back and forth if to much short block engine if you dont know engine very well you will have to take to shop
Sep 14, 2014 | John Deere Garden
1996 honda accord starts up fine runs 10 15 minutes engine shuts down wait 5 ,10 minutes starts back up shuts off short time after
sounds like there could be a problem somewhere along the fuel line either between the pump and that engine or between the filter and the engine i have a car that would do the same thing turned out to be the fuel filter was full of **** ran like a dream after i changed that.
Jan 10, 2012 | 1996 Honda Accord
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
1996 Achieva with Quad 4 engine, drives for about 10 miles then just shuts off, after it sits about 30 minutes it will fire right up and go for short distance then does it again. I have replaced cracked...
Have you checked the fuel pressure when the car quits on you.It sounds like a fuel pump that is overheating and binding up when it gets really hot.Then after cooling it will work till it heats up again. Good luck
Oct 29, 2010 | 1996 Oldsmobile Achieva
Engine acts like it is vapor locking.. Can Mow 30
heat related problem, probably needs the valves adjusted. When the engine gets hot the valve clearances change
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
98 Buick Regal -engine quits
ok its one of two things you need to check when it cuts off if you have spark or fuel if you lose fuel pressure replace pump it gets hot and makes noise like its running but its not pumping fuel and if you lose spark you need to replace ignition control module has a hair line crack in it and when gets hot the crack expands and loses contact and wala no spark
Aug 15, 2009 | 1998 Buick Regal
.1 liter Chevy engine runs 15 to 30 minutes then will shut off.
Sounds like the coil. A bad coil will lose internal connection when it gets hot.
Feb 26, 2009 | 1999 Dodge Durango
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
