Question about Clarion DB265MP CD Player
How to do Clarion DB265MP FM tuning in 0.5 Khz
I need to know ways to unlock Clarion DB265MP secret menu to enable European Tuning (0.5 Khz). Please help.
2 Suggested Answers
  • 3 Answers
SOURCE: clarion drx9375r tuning radio
To change stations, make sure you are in radio mode(push the FUNC button in upper left corner), and move the 4-way button Left or right. To add station to presets, press and hold preset button until it is saved.
Posted on May 01, 2009
How do i reset a sony STR-K740P receiver??? - Sony Str-k740p Radio Receiver
Tuner reset
You can change the AM tuning scale to 9 KHz or 10 KHz. After tuning in any AM station turn off the receiver. Hold down the Preset tuning + and - ve together.
All preset stations will be erased when you change the tuning scale. To reset the scale to 10 kHz (or 9 kHz), repeat the procedure. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 12, 2016 | Sony Audio Players & Recorders
FM frequecy increases/decreases too mugh pr. step
Hi, Your post/description "the frequency increases in steps of .2 Mhz or 200Khz" refers to the increment of frequency spacing between tuning steps and is largely dependent on the radio standards of the country/region the radio is intended to be used. Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sep 13, 2007 | Makita BMR100 Radio
LS. How do I reprogram the frequency bandwidth on FM on a theftlock radio?
You are confusing AM channel spacing with FM tuning. Some radios have a switch for selecting 9 KHz or 10 KHz spacing.
Jan 28, 2016 | 2002 Chevrolet Blazer
How do I change language on pioneer deh4600bt
Section
02
Using this unit
(iPod control)
c
This unit's iPod function is operated from your
iPod.
d
(Bluetooth indicator)
Set up menu
After installation of this unit, turn the
ignition switch to ON.
SET UP appears.
Turn M.C. to switch to YES.
# If you do not use the unit for 30 seconds, the
set up menu will not be displayed.
# If you prefer not to set up at this time, turn
M.C. to switch to NO.
Press M.C. to select.
Follow these steps to set the menu.
To proceed to the next menu option, you need
to confirm your selection.
LANGUAGE (multi-language)
This unit can display the text information from a com-
pressed audio file even for information embedded in
English, Russian or Turkish.
! If the embedded language and the selected lan-
guage setting are not the same, text information
may not display properly.
! Some characters may not be displayed properly.
1 Turn M.C. to select the desired setting.
ENG (English)-??? (Russian)-TUR (Turkish)
2 Press M.C. to confirm the selection.
CLOCK SET (setting the clock)
1 Turn M.C. to adjust hour.
2 Press M.C. to select minute.
3 Turn M.C. to adjust minute.
4 Press M.C. to confirm the selection.
En
FM STEP (FM tuning step)
Use FM STEP to set FM tuning step options (seek
step settings).
1 Turn M.C. to select the FM tuning step.
100 (100 kHz)-50 (50 kHz)
QUIT appears.
! The manual tuning step is fixed at 50 kHz.
! When AF and TA are turned off, the seek step is
fixed at 50 kHz even if set to 100.
5
To finish your settings, turn M.C. to se-
lect YES.
# If you prefer to change your setting again, turn
6
Notes
! You can set up the menu options from the sys-
tem menu and initial menu. For details about
the settings, refer to System menu on page 19
and Initial menu on page 23.
! You can cancel set up menu by pressing SRC/
OFF.
Basic operations
Important
! Handle the front panel with care when remov-
ing or attaching it.
! Avoid subjecting the front panel to excessive
shock.
! Keep the front panel out of direct sunlight and
high temperatures.
! To avoid damaging the device or vehicle inter-
ior, remove any cables and devices attached
to the front panel before detaching i
Feb 08, 2015 | Pioneer Deh-5400bt Car Stereo...
Old manuals
You have buttons to press to change the modulation.
FM covers regular FM band: 76 MHz (Japan) to 108 MHz and the higher frequency ones used for Air and Weather.
AM covers the Long waves (in Europe), the regular AM band (520 kHz-1700 kHz), and the Short wave bands 2MHz 30 MHz
It seems that you can tune the frequency in by direct entry with the number keys.
I do not see the image of the face of the radio but from my experience with many Grundig/Eton you should have two buttons with arrows (left A and Right Arrow) or two buttons with + and Minus (not the volume buttons). If you are in SW, pressing one of the buttons changes the tuning to the adjacent Meter band.
Jan 09, 2014 | Grundig G4000A FM/AM Radio
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
Frequency increases/decreases in steps of 0.2 kHz
Hi again, Seems you posted twice. A copy of my reply to your other post.... Assuming no hardware fault to the radio, tuning steps may be adjusted by: 1. With the radio switched off, press the Step/Band button for about 2 seconds. This will display the current FM tuning step (200Khz as in your case); 2. With the radio switched off, press the Step/Band button for about 10 seconds. This will display FM and a blinking 50Khz with a single beep sound. By rotating the Tuning Control you can increase or decrease this value. 3. pressing the Step/Band button again will move you to the tuning increments of the AM band again adjustable via the Tuning Control. 4. pressing the Step/Band button again will save the setting and complete the process. Hope this be of some help. Good luck and kind regards.
Sony ICFM350S
I would like to know how to change the MW Tuning Interval from 9Mhz to 10Mhz.
The radio is a Sony ICF - M350S
Thank you
RM
May 12, 2007 | Sony ICFM410VLIV AM/FM/Weather/TV Radio
AM Tuner off by 1-3 khz. How to reset?
Yes,removing the battery and going back to reset can help, also check for moisture, when the battery is removed try to apply some heat with a blower into the receiver housing to clear moisture, then try the set again.
Apr 19, 2007 | Sony ICF-M410V AM/FM/Weather/TV Radio
JVC KD-G300
Here is a link to the manual: http://books.jvcservice.com/download/718134980/32506.pdf There does not appear to be a way to set tuning to european standards. Is there a particular reason you want to be able to tune those frequencies?
Mar 12, 2007 | JVC Sirius KD-G300 CD Player
Clarion DB265MP CD Player Logo
42 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
