Question about Linksys Wireless-G Broadband Router
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
  • 404 Answers
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Posted on Aug 02, 2009
  • 2,260 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Mar 14, 2010
How do I connect to my computer with AT & T DSL connection? I only see one ethernet port on back of computer tower.
If you just bought the router, you will need to insert the router between your computer and your ATT DSL Modem. The cable from the wall goes into the modem (should already be that way) then the Ethernet cable from the modem should now go to the source of your Linksys Router. then use one of the ethernet ports from your router into the ethernet port on the back of your computer tower.
Use the documentation that came with the Linksys for more information on setting it up.
Good Luck
May 11, 2011 | Linksys Wireless-G WRT54GS Router...
Cannot connect to att DSL through Linksys router.
hi
I've tried:
Having the router get an IP automatically from the modem.
Changing the router's IP address.
Having the modem pass PPPoE authentication to the router.
Bridging the modem.
Power cycling the guts out of everything.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
I am trying to install att 2 wire dsl on a friends computer. the inter net is suppose to be on now, i am trying to set it up for her. i have the 2 wire modem hooked up and tryed running the cd. it says...
Verify that the software you are trying is COMPATIBLE with the operating system on the computer.
Try removing the software and re-installing it in SAFE mode before plugging in the USB or Ethernet cable.
Jun 10, 2010 | Computers & Internet
Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Apr 25, 2009 | Motorola Computers & Internet
Have changed to att may I use linksys modem
Yes, you can still use the Linksys router with your ATT dsl modem. Could you provide me with the model or brand of your ATT dsl modem so I could provide you with the steps on how to setup your router?
Feb 27, 2009 | Linksys EtherFast Cable Modem with USB and...
Re-installing my linksys
Before you can use your linksys router again, you must configure first your AT&T modem under bridge mode. If the AT&T modem is already set to you may connect the devices (modem router and PC) must be switched OFF first.
after the devices had been connected,...
1) turn ON the AT&T modem first, wait for the DSL light to stay solid
2) turn ON linksys router,wait for the lights to stay solid
3) turn ON computer,wait for your desktop screen
4) try to access Internet Explorer
Nov 13, 2008 | Linksys Wireless-G WRT54GS Router...
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Wireless network broken, access to WRT54G & Motorola 2210-02 via http.. denied
I have att yahoo dsl which I installed about a year ago. The process required bridging the ADSL Modem (in my case a speedstream 4100) and accepting dynamic IP addresses and configuring PPPoE on the WAN side of my Linksys router. The ATT support person walked me through the entire process over the phone even though I was comfortable with making the Linksys configuration changes as I had to do the same in China without technical support. The modem configuration was no more difficult than the router configuration as it was performed from a web browser too. The biggest warning was that to reverse the modem change (if desired) required use of a reset button because the web interface was disabled as a result of the configuration change. My advice to you especially if you are willing to attach the Linksys router to the telco modem is to contact the ATT highspeed DSL support line and see if they will walk you through it like they walked me through it. Reviewing your Linksys User's Guide and understanding the configuration of that device would probably be appreciated by the ATT Support person as well as assuring you can access the Linksys router to configure it during the call.
Dec 08, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
251 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
