The battery is fully charged, but it won't work. I think the problem is that the two parts of the trimmer aren' In contact, but I can't separate them to try again. Any ideas?
SOURCE: parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
SOURCE: My EOS rebel XT just
Sometimes the battery contacts will get a slight buildup of oxidation, and need to be cleaned. Use alcohol and a qtip, or a pencil eraser.
Here is a website that discusses some things to try for a dead camera:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If none of those suggestions help, you could have a bad on/off button. Take it into a local camera repair shop, and get an estimate on the repair.
Or you can contact Canon support:
http://www.usa.canon.com/cusa/consumer/standard_display/support
On some cameras, you have to take the entire body apart to replace the switch, but if you're a patient, tecchie type of person, you might be able to do it yourself.
Good luck, and hope this helps.
SOURCE: I have a fairly new
Have battery tested for load capacity, moter could be defective, check fuse
SOURCE: flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
SOURCE: How long should a fully
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E
jQuery(document).ready(function($)
$("a[rel=product-image-gallery]").fancybox(
'transitionIn' : 'elastic',
'transitionOut' : 'elastic',
'titlePosition' : 'over',
'titleFormat' : function(title, currentArray, currentIndex, currentOpts)
return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + '';
Testimonial: "Thanks for the help - thought battery was meant to last over an hour."
