SOURCE: How to Remove IR400 Dept. ID and Password
Hello, did you try the Clear MMI function ? , it should reset all passwords if my memory is good ( and all settings like ip, language etc ... )
Regards, Mug.
SOURCE: canon iR2016J
Dept. ID is activated that is why it is asking you to enter it. If you are not needing the function you can ask the local service provider to check the settings of your machine.
SOURCE: our canon D1120 has started
you can reset Dept.id and password.
press additional function and then 2 and 8
now go to clear
clear password and restart machine.
SOURCE: Enter DEPT.ID & DEPT.ID Password
You will have to reset/clear the password. This WILL REMOVE all passwords setup in Dept ID Management. Go into Service mode by pressing the Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, PWD-CLR, Then Ok. You may also use the arrow keys on the display to get to PWD-CLR. Then the RESET key or maybe power down the equipment.
