Question about Callaway Big Bertha 460 Driver
Ive owned x14, x-16 and x18 irons i keep snapping the shaft of at the hossel, im a 3 handicapper the x-18s are only a couple years old, broke 2 in the spring and 2 yesterday, getting to be a royal pain in the ****, it takes 2 weeks to get them back, not so sure i want to keep buying your product, anyone else having concerns, brought the shafts down to golf town, showed the guy, no signs of rust, just clean breaks, maybe you can e-mail me back at simps2008@hotmail.com
  • 3 Answers
Installing a ferrel on the shaft prior to club assembly will strengthen the shaft at this vunerable point. Your swing might be a bit steep at impact and this puts tremendous stress on the shaft.
Posted on Aug 01, 2009
I bought a Danby Microwave 2 year ago and how it is RUSTING or burnt as Plastic is crack and flaky around top inside edges. How dangerous is this to your health.
well im not a doctor , but I do know about metals a lot . rust is oxidized steel , that at least a good part of it is the mineral iron, now ive heard that your blood needs iron daily to keep healthy , its just I do not believe that the rust enhances the taste of your food
Oct 20, 2016 | Danby Microwave Ovens
My samsung slide phone broke. It stills works
You didn't say how what model it is, or how old it is, but if it is more than 3 years old, it is time to ditch that one after getting a new one, transferring your notes, contacts, and any photos into the new one.
Mar 08, 2018 | Cell Phones
What is the recommended bar spacing for a bird cage for doves?
I have found a chart that outlines the appropriate bar spacing for several breeds of birds, hope you find this helpful.
Species
Minimum Cage
Size
Bar Spacing
Finches
18"x30"x18"
1/4" to 1/2"
Canaries
18"x24" x18"
1/4" to 1/2"
Budgies
18"x18"x24"
1/2"
Cockatiels
20"x20"x24"
1/2" to 5/8"
Lovebirds
Parrotlets
24"x24"x24
1/2"
Ringneck Parakeets
24"x24"x36"
1/2" to 5/8"
Conures
Poicephalus
24"x24"x24"
5/8" to 3/4"
Caiques
Pionus
Jardine's
24"x24"x36"
5/8" to 3/4"
Amazons
Mini Macaws
Goffin's Cockatoos
African Greys
24"x36"x48"
3/4" to 1"
Large Cockatoos
36"x48"x48"
1" to 1.5"
Large Macaws
36"x48"x60"
1" to 1.5"
Doves and Pigeons
*see below
1/2" to 5/8"
Aug 29, 2012 | Birds
My Bosch dishwasher SHX 46a 05uc will not pump the water out when done with the wash cycle or rinse cycle
1 Remove the pump and drive motor. You willfind two plastic and one rubber motor couplings. One is located on the drivemotor and the other is on the gear case with the rubber coupling between them.
2 Pry or break the old couplings off with your screwdriver. Replace with newcouplings. Simply push one onto the shaft of the gear case and press the secondone onto the shaft of the drive motor.
3 Line up the holes of the rubber isolation coupling with the studs in thecoupling. Push the rubber isolation coupling in place.
4 Push the isolation and coupling on the drive motor making sure that theholes line up with the studs on the other coupling on the gear case. · 5 Reinstall the drive motor and then snap the pump in place with the retainersto hold it in place. Reconnect the hoses with the clamps and snap the.Put thewasher back on and screw the back in place. Position the washer where you hadit before and plug the washer in.
Good luvk and thanks for using fixya.
Jul 27, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Broken Dremmel tool spindle stop turning but motor runs
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
Dec 23, 2009 | Dremel & Stylus Lithium Ion Cordless...
My 2 year old stuffed a couple of coins intoPS3
open it and try to get the disc port open on then just take out the coins and put it back together (and try to keep coins away from your 2 year old)
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Wont spin
Broken coupling. Why you may ask do I know this? Easy. the motor not only drives the washer, is pumps the water. How? It has the pump mounted on one side and the other side connects to the transmision and that is the week point. At that point between the motor and tranny is a coupling. The job of the coupling is to transfer power from the motor to the transmission. It consists of 3 parts. It has a central black piece to house the fingers of the 2 outer pieces. Start by replacing the 2 outer pieces. Install them flush but not binding to motor and to the tranny. I use a nice fitting wooden dowel. It keeps me from forcing the endpice past the end of the shaft and binding. binding ain't good. Each endpiece has 3 fingers. I place the endpiece on the tranny at 12 oclock. I place the end pieces on the motor at 11 and 2 oclock. I make sure all 4 motor mpounts are snug and I snap the motor down to the tranny using the clips provided. I snap the pump on. Replacement of that old coupling is complete. In order to do this operation the cabinet of the machine must be removed. Their are several good sites that show how to remove the cabinet. I like this one my buddy Jimbo made on replacing the clutch. Now you probably will not be replacing the clutch any time soon but this guide shows you how to get to the coupling.
http://repair2000.com/coupling.html
here is one made by my buddy AJ at appliancejunk.com:
http://appliancejunk.com/motorcoupler.pdf
This is one I made just for fun to see uncle jack run:
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
Apr 30, 2009 | Washing Machines
I have had 2 Shark irons and both simply stop turning on
The cost of repair is more than the cost of a new one. Therefore, trash it and buy a new one.
Mar 11, 2009 | Euro-Pro Shark GI490 Iron
Coupling broke
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Rating Locked! (?) lexrehabtech has rated this solution as Helpful
Oct 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Callaway Big Bertha 460 Driver Logo
127 people viewed this question
Top Callaway Sport & Outdoor - Others Experts
Bill Eager
Are you a Callaway Sport and Outdoor - Other Expert? Answer questions, earn points and help others
