Question about Audiovox 8610 Cellular Phone
How can i separate the flip to replace the ribbon or flex cable
    Brigadier General:
  • 7,752 Answers
It is adviceable for you to take the phone to a mobile repair center and have them fix it for you...
Posted on Aug 01, 2009
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
Jun 22, 2010 | Motorola Mobility RAZR V3
How do you fix the loose cable ribbon to the LCD screen? The screen is on and lighted but I cannot see any information. No Caller Id, text messages or contact info.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jun 04, 2010 | Motorola Mobility Hint QA30 Cell Phone
My phone is not turning on, the keyboard lights up
Your lcd is probably ok, it's just a part called the flex cable (a ribbon cable that connects the board to the lcd). If the flex cable gets kinked or torn stuff like this can happen. You can find flex cables on ebay for cheap, but they are kind of tricky to replace in flip phones. There are some sites you can send it in to for repair, and there are sites like ours where you can trade it in for another phone.
www.usedcellphoneshop.com
May 08, 2010 | Samsung SYNC SGH-A707 Cellular Phone
The ribbon has snapped
This is a very common problem for this model phone. The lower flip assembly usually breaks as well where the cable runs through it. A new flex cable and housing can be ordered on ebay. The V551 should be the same cable and housing.
Dec 09, 2009 | Motorola Mobility V550 Cellular Phone
No flip top light for Motorola flip top phone Model V276
Most likely a flex cable. The flex cable runs through the hinge. It is a high fail item. I used to replace 20 a week. Check to see if you can find a flex cable online. You will also need a small torx driver. I cant remember the size.
Jul 20, 2009 | Motorola Mobility V276 Cellular Phone
Both screens on my bb 8220 flip phone do not work phone still works though
check the connection between mother board and the screen.Its a flex/ribbon cut-not working anymore.better to replace a new flex/ribbon for you Flip BB.
Jul 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
3230 help.,
The flex cable is the weak link in all Flip style phons, so yes replace the ribbon/flex cable and most likely it will cure the problem.
Oct 28, 2008 | Nokia 3230
Acquiring satellites
Try flipping the back part up.
Jul 01, 2008 | Garmin nuvi 350 GPS Receiver
Back light intermittant
You probably have a defective flex cable... comes with the lcd screen....
Jan 17, 2008 | Motorola Mobility i530 Cellular Phone
Samsung slider phone
hi reckon you have a faulty ribbon cable replace and it should be ok thats if a software flash doesnt sovle ya problemas lylo recommends mrjazon
Jun 18, 2007 | Samsung SGH-D600 Cellular Phone
Audiovox 8610 Cellular Phone Logo
41 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
