Question about Garden
My mower runs great for about 1-2 minutes and then stops. It will keep going if i press the primer bulb every 2 seconds. I have cleaned carb and filter and fuel line and take. Still the same problem.
  • 6,674 Answers
Take a good look in tank for debris near drain to fuel line.
Posted on Aug 03, 2009
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
Starts and then stops after couple of seconds. will continue to run if I keep pressing primer bulb.
Most likely the high speed jet on the bottom of your carb is plugged.
not allowing fuel up into the venturi into the carb .
Oct 25, 2009 | Toro Garden
Must keep pushing primer bulb to keep mower running, need manual
The main suction jet in your carb. is blocked.Remove the bowl and push a thin needle up the centre jet in the carb and blow the jet out with compressed air. Stephen.
Sep 22, 2009 | Briggs & Stratton Garden
My lawnboy 10304 runs about one minute and shuts down. Any ideas?
It sounds like it is 2 stroke.
Carefully remove the carb bowl, by undoing the brass bolt.
Examine the brass bolt for a small pin-hole in the side.
Use a piece of corn-broom NEVER anything else !!! and poke the hole(S) to make sure they are clear.
Blow out with air if available.
You can use this method to clean out all the carb orifices carefully.
Hope it helps,
Andy.
Jun 15, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Mar 20, 2009 | Champion International Champion& Small...
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
