Question about Canon PIXMA iP3000 InkJet Photo Printer
Ip1300 mo tanya gimana ngilangin ink absorber warning
    Problem Solver:
  • 20 Answers
ReSet it counter numbers,
PressNhold Reset - Press Start
Hold Start - double click Reset
Release both
Press Reset 4 times turn off machine,
It is described in Canon Manual available at 2Manuals.com. ($8.99) also shows the actual ink asborer mats get a set of absorbers part number QY5-0145-000 - remove the machine side
then top cover , 4 screws, better heve rubber gloves
bat(^m^)ike
Posted on Feb 11, 2008
Plz solve me problem\r\nmy canon ip1300 printer absorber is problem
This mayclear the ink absorber problem.There is ink absorbers located at both ends ofthe printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 07, 2011 | Canon PIXMA iP1300 Printer
Full ink absorber
There are ink absorbers located at both ends of the printerwhere the ink head move.
Then take several sheets of absorbent tissue, fold it into a pad and place it insidethe printer over the ink absorber on the far left hand side of the printer tosoak up the excess ink. You may need to change the absorbent tissue a fewtimes. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jun 15, 2011 | Canon PIXMA iP1300 Printer
General error with epson tx111
mw tanya saya punya epson TX111 gimana cara mengatasi general error ketiga lampunya nyala bersama sama..mohon bantuannya...
Oct 10, 2010 | Epson Office Equipment & Supplies
An error occured. ink is running low. view the ink details the ink absorber is full what the solution is that problem?
Ink absorbers do fill up and can be replaced.....however the printer can be placed on a tin foil sheet as a safety shield.
To reset the printer, with it turned "ON" remove the power cord from the wall plug. wait about a minute.
Hold down the "ON" button and and plug the printer in again while still holding the button down. Count down from 15 and when your done release the power button.
The printer is still off so again press the "ON" button.
The absorber is now reset, but the printer does have waste ink inside that can leak out........you are warned!
Sep 22, 2010 | Canon PIXMA iP1300 Printer
Ink absorber needs replacement on our ip1300
Supported OS: Windows 98 / ME / 2000 / XP (J/E version) : QY9-0069
Distribution method: Provided by SSIS (Download “ iP1300 Service Tool” from software
download in SSIS.)
Jul 13, 2009 | Canon PIXMA iP1300 Printer
My Canon ip1800 ink absorber is full is there a quick fix
No .You must replace waste ink tank.
to get printout
Jul 01, 2009 | Canon PIXMA iP1300 Printer
The canon pixma ip1300 was full of the ink absorber,what is the solution of it,and what i do for the ink absorber?
You need to reset your printer and replace the absorber.The absorber is on the bottom of the printer and you need to disassembly the hole printer to replace it.For reset the printer look this: http://tricks-collections.com/iptool-canon-printer/
Jun 12, 2009 | Canon PIXMA MP760 All-In-One InkJet...
MY PIXMA iP1300 keeps error
since canon printers need service tool to reset the waste ink counter, i suggest that you bring your printer to an authorized service center in your area to have them reset the waste absorber counter and clean it as well.
Feb 15, 2009 | Canon MP610 Photo All-In-One Printer
Printer problem
The ink absorber (a felt pad) is provided so the ink lost during cleaning has a restricted area to ensure the ink doesn't escape into mechanical areas of the printer.
I haven't seen the inside of your model but this is probably being monitored using reflected light and once the reflection is reduced (pad changes from white to dark) this warning is triggered.
The printer has been disabled to avoid cast-off ink from overflowing the recess in which the pad is installed.
Unless you are very good at finding the sometimes many snaps that hold your printer together, it should be turned over to a professional.
As a retired tech, I need to warn you that the cost of labor and the pad needed will probably exceed the cost of a new printer.
If you decide to replace it, be advised that most printers are supplied with only minimal amounts of ink in their included ink cartridges; please consider buying cartridges along with the printer to have available when the original cartridges run dry.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
126 people viewed this question
old marine
old marine
