Question about Canon PIXMA MP760 All-In-One InkJet Printer
Problem with printing Black on MP760
Black print dirty, patchy or none existant. All cleaning, head alignment procedures etc seems to make matters worse. On Nozzle Check printout cartridge 3eBK info is virtually non existant. On Manual Alignment printout, columns A and G are virtually non existant. Colours printing OK. All cartridges are Canon original and have sufficient ink.
  • 1 more comment
  • jackoviejo Aug 04, 2009
    Printer is showing all cartridges at least half full. Will purchase new cartridges in order to confirm whether this is the solution to the problem.
  • jackoviejo Aug 08, 2009
    Whilst waiting for delivery of new cartridge, soaked existing cartridge in petrol etc., as suggested. Still waiting for ink to stop dripping out of cartridge when inverted for installation! Black seems to be the only problem. Where colour selection is available, can print all docs in eg. dark blue or any other colour. Printer LCD still shows 3e BK cartridge as half full even when removed from printer and still prints with cartridge removed. Is this normal?
  • jackoviejo Aug 13, 2009
    Have installed new 3eBK cartridge. Printer readout still shows cartridge as only half full. Nozzle check prints no data for this cartridge, but all other cartridges OK. Auto head alignment failed; printer suggests manual alignment, but printout shows no blocks for first column (A and G), although all other blocks OK, and no black printing eg.column identification A to L or adjustment scale eg +7 to -3.
  • Canon Master
  • 3,866 Answers
Replace the ink trash bin is what its called with a new one that should shore this up as when it get full the printer does not print well at all having this issue, Since you did some cleaning already you may have a clogged plunger or a bad plunger witchever comes first.
1. trashtray
2. cloagged or damaged plunger
If you are still having issues you might have a dired cartridge this is possible. Do not shoot the messanger here as I cannot see what is actually happending on your allighment page printout but try those steps it also will not hurt to visit canon troublshooting site.
Thanks
Rulds2008
Posted on Aug 13, 2009
  • 813 Answers
Might be the ink in Black Cartridge is dry. Try changing the cartridge and then check if same happens with the new one?
Posted on Aug 04, 2009
  • Dixit Sardana
    Dixit Sardana Aug 04, 2009
    You can also try this:
    Take out the black cartridge, insert it in alcohol or petrol for 4 - 5 hours, take it out, clean it and let if dry for 2 - 3 hours, clean the cartridge, insert it back and then check.
Hi there
It should not be detecting the black cartridge on the display if it has been removed. I would avoid placing the petrol-soaked cartridge in again as it may leak into the printer.
The best option is indeed to wait for the arrival of the new cartridge and see if it helps.
Please do not rate this reply or your reply will not be returned to me.
Thanks
Posted on Aug 09, 2009
Black ink will not print on Pixma mp760
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Dec 20, 2011 | Canon PIXMA MP760 All-In-One InkJet...
My printer Canon MP760 does not print black.
Your black ink must be empty replace with a new one and print.
Sep 20, 2009 | Office Equipment & Supplies
Incomplete patchy printing
Please try to do a printer head cleaning. You can do it by getting a small earbud and soak it with a small amount of water. Or try to adjust it by doing an alignment. Usually, the printers have this functionality. Please refer to the user manual.
Aug 13, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Grid pattern on Canon MP760 test print is patchy and cleaning process does not fix it.
You can try to remove the print head and ink cartridges.
Soak the head in an ammonia10-20% solution with warm water for 30-45 min.
Dry the head completely and re-install.Now run your grid patter,
It sonds like(from the grid reference)that only the black is clogging.This is a pigmented ink and tend to dry if not used for months at a time.
Jun 20, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon MP760 black ink dull and has stripes
Take the cartridges out and also the printhead and set the nozzle of the printhead on a 5-sheet pile of kitchen paper that was make wet in the middle with some lukewarm demineralized water ( water for an iron )there is not much necessary if there are clogged nozzles deep inside the printhead buy cartridge flush different methode for printers to find
How To EASILY Unclog Ink Jet Print Heads
Aug 26, 2017 | Canon PIXMA MP760 All-In-One InkJet...
Patchy printing
Problem is with either with cards or with print head's mechanical alignment. Try with some different cards and for head get it tested by some authorised service person.
Nov 28, 2008 | Evolis Pebble 3 ID Card Printer Package...
Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
May 13, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
The black cartbridge is not printing and won't align
Dies this model have a separate print head? Or is the head part of the cartridge? If it is the latter then it seems to be a data transfer problem- which means possibly the contacts in the machine that mate with the contacts on the cartridge are dirty or damaged. In the first instance try gentle rubbing with a moist tissue the in machine contacts then try. Also try the Lexmark website Tech Support Team.
May 20, 2007 | Lexmark X6170 All-In-One InkJet Printer
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
old marine
old marine
