Question about Element Electronics FLX3210 32 in. LCD TV
I have a Element 32" HDS LCD TV, movel ELEFLX3210. It won't tunr on, but has a red light that is on. The TV was purchased 09/09/2007. Do you know how to repair or address this? It's a $549 TV.
  • n1ghtfl1ght Feb 07, 2010
    same prob here main board i think?
    Scholar:
  • 73 Answers
There were two runs of parts on this model, one using a powersupply board that included the inverter and one with a separate inverter. The red standby light failure was typical with the second run with the all in one power supply board. You can tell if you have the second run by opening the back. If the power supply board says proview and is black then you need to replace the board underneath it. The main board. This model also had a MASSIVE factory defect. If you hook up the VGA model, pin nine on the control box lead shorts out and it goes into limbo like you have now. So, replace your mainboard and Fill the vga input with hotglue. That should get you back and kicking again. Try shopjimmy.com or ebay for parts.
Good luck
Posted on Mar 21, 2010
  • Axle80
    Axle80 Mar 24, 2010
    Response to solution 2, its neither of those boards. The mainboard is the green circuit board that has the silver philips tuner box on it, its also connected to the input ports. The T-con board is the lcd controller. You need to open your tv and find the exact part number of the mainboard and replace that one. The board number of the tv I recently repaired is: 200-107-JL321XA-DH. Dont go by this number though, find the similarly numbered board on your set and find the exact match.
    Good luck.
I have the same problem
Posted on Aug 23, 2009
  • 37 Answers
Power on then turn off will also run when unplug
Posted on Apr 23, 2010
So this is the board that needs to be replace?
http://www.shopjimmy.com/catalog/product/view/id/179477/s/proview-55-31t01-147-t-con-board/
or is it this one?
http://www.shopjimmy.com/catalog/product/view/id/182343/s/element-200-p00-hivi150-power-supply-unit/
i have the same problem, the red light is onm but the tv wont turn on. i did plug a laptop many times to watch netflix movies :(
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I have an Element FLX 3210 that won't light up and show a picture..it has the sound but no picture.
Check the two caps (10uF 450Vdc) by the inverter transformers, also check fuse F2.
Worst case will be shorted out ballast caps in the LCD panel assembly.
http://s807.photobucket.com/albums/yy352/budm/Element/Element%20FLX-3210/
Jun 04, 2011 | Element Electronics FLX3210 32 in. LCD TV
My 32" Element LCD tv is broken. One night I was watching tv and all teh sudden there was blue, red and yellow lines running horizontally across teh screen, audio was fine. I turned it off and unplugged...
Yes!
It has suffered a breakdown in the power supply and the damage has also spread as far as the sustain boards that control video and convergence. This is not a DIY and the repair for parts is $300 + labour. However, get a few quotes. At least a 32 in is a little more transportable than a 6' model
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Element ELC-HS321 32 in. LCD TV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Element 32" TV. Power only for a few seconds, no audio.
Yes, look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=FLX3220F+
Please post back what you find.
Dec 22, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Flashing red ''M'' all over Screen
As you have only recently purchased the TV and it is misbehaving right in the begining, then I suggest that you return and replace it with another piece. Or another brand if possible.
Nov 08, 2009 | Element Electronics ELCHS371 37 in. LCD TV
Element LCD TV owners - Using the VGA port may crash your TV!
I bought two of these tv's and they worked fine,I hooked up a computer to both of them and blam smelt smoke in one and the other wont come on either. The computer takes them out. It is a common problem with this TV.
Nov 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Konka KLC 1508U
I had to purchase a new adapter from radio shack.
Nov 06, 2008 | Konka DLC-3211UT 32 in. LCD Television
Element Electronics FLX3210 32 in. LCD TV Logo
1,877 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
