Question about Panasonic Televison & Video
Panasonic pt 50 lc 13 tv 50 ins
There is a flat 3 to 4 ins long sort of ribbon connector made up of abount 20 strands all blue except 2 gold that connects between the engine light assembly kit to the signal board.
it is the only one of its kind in the back of the tv.
I need the correct description of the part and its number to order a replacement.
thank you
SOURCE: Replacing STK392-110 IC Panasonic PT-51HX41 51 in. Rear Projection Television?
TV Tech - well another issue has cropped up today. The TV turns on for about 15 secs and then automatically shuts off. Seems like a power supply issue but not sure.. Your thoughts?
Posted on Oct 08, 2007
premtech
  • 934 Answers
SOURCE: PT 50LC13-50 Panasonic TV
Going through bulbs that quickly would indicate to me a problem with the ballast or smps (switch mode power supply). It's not something you want to just run out and replace (expensive).. Call a reputable shop and tell them what you're experiencing.
I do know that they should check the value of C1330 in ballast circuit. If it is a .22uf, There is an upgrade kit available for it, panasonic p/n# LSUC0022
Posted on Nov 05, 2007
SOURCE: Panasonic PT-47WX53G Projection TV - convergence problem, can not align completely
I don't know why that guy told you to replace your "DC" board (that is the one you mean, right?) More likely than not, it's your convergence amp integrated circuits (ICs). I had what I think was the same problem (on the same exact model TV) you described, and I looked around alot of blogs and DIY websites, and this seems to be the most prevalent root behind these convergence problems. I ordered the two chips for twelve bucks (for both), spent a few extra bucks (like $35) on some electronic tools / solder supplies, and followed procedures laid out here at http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html, as well as paying strict attention to the service repair manual (which you said you already have?). The result? No more convergence problem, and I saved myself around $400 - $550 over having it done by a professional.
Seriously-- I bet this is the culprit. Just make sure if you're gonna do this that you FIRST check the six resistors (located at spots D-7011 thru D-7016) to make sure there are none burnt out / opened. It may be that one of those is fried also / instead. Since they are far easier to replace, it's good just to rule them out first.
And by the way, just FIY, when I did this I had kept the TV unplugged for about two weeks first, cuz I wanted to make sure all the capacitors were discharged and safe. Did I need that much time? Maybe not (some have said a few hours is sufficient), but I was also primarily concerned about the Flyback Transformer and its wires, which have the highest voltage (up to 30,000 volts) and can hold a charge pretty long. And I'm still here to write about it. So, check out the link, and see if you'd like to try this yourself, as well!
Posted on Jan 16, 2009
SOURCE: Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Posted on Jan 22, 2009
  • 159 Answers
SOURCE: panasonic PT-61LCX65 tv has color spots
if you mean color spots size of a dime or so.
  • easiest: it is dust in some step of the projection light path.
  • hardest: the light engine could be damage
if you mean little ones as little dots (a neddle punshing) red and blue but always there:
  • condition call it: pixels always on: light engine is the reason.
as you see the light engine is the main part here, IT is expensive repair. so if you can survive with those little dots do it.
IF it is dust, is good idea asking for and estimate to see if can works.
Posted on Apr 18, 2009
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
There is a black line across the middle of our picture on our Panasonic 50 inch plasma TV. Do you know what is causing this and how we can fix it?
1 of 2 things can be wrong. Bad panel, or a ribbon cable that needs to be reseated.
1. take a piece of tape and stick it where the line is. So you will know what cable you are looking at.
2. unplug the TV
3. Take the back off of the TV
4. If you look at the far left side of the set, you will see a whole row of ribbon cables. Find the one that is in the same location as your piece of tape.
5.Disconnect the ribbon cable. This is done by simply flipping the connector up and sliding the cable out.
6. Put the cable back in. Make sure it is straight and all the way in, then push the connector back
7. Reassemble your set, plug in and see if the line went away. If it did, great!!! If not, you have a bad panel.
The only fix then would be to replace your panel. Would be more cost effective to replace your TV.
May 06, 2011 | Televison & Video
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Panasonic TH-50PX20U plasma problem
There will be a fault with the plasma screen, you will have a dual scan type which is why it only covers half the screen. It is possible the flat ribbon connector to the screen internallly may have become loose7 needs to be re-fitted securely, but most often it is a replacement screen is required.
Sep 25, 2009 | Panasonic TH-50PX20U 50 in. HDTV-Ready...
Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Jun 24, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
