Question about Garden
I have a Scotts 16hp 42'deck that won't start. I've replaced the carb, but, now there seems to be a problem with the wiring. One wire appears to overheat when i apply booster cable to the battery. I need a look at the wiring diagram to see what would cause what seems like a short circuit or something.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
This is almost always caused by a bad ground from the battery to the frame.check the battery cable where it bolts to the frame and the connection on the battery it is probably loose or burnt.If you ground to the frame is bad the starter current will try and run through any wire that leads to ground and this will cause the wires to melt.
Posted on Aug 02, 2009
Lawn mower won't run. Cannot start it.
sometimes the primer bulb gets cracked and wont properly pump fuel into the carb. replacement of the bulb should fix the problem.
Jun 15, 2013 | Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Scotts 16hp Tractor stalls going downhill ?
Check fuelpump pickup filter position in tank
Oct 14, 2017 | Garden
My dls 3500 mower will not start at all, I charged the battery but the engine wont even turn. All the wiring and fuses seem to be ok
I had the same problem. I replaced the wiring harness for a short fix, corrosion in the terminals that connect to ignition switch. This worked for a while. Then replaced ignition switch this also worked for short time. Now I just open the hood to reach behind the ignition switch and wiggle wires while turning key to start until it starts keep wiggling to get good contact. If it won't stop after it starts, wiggle wires after you turn the key to off. It will stop.
May 29, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 16hp B&S, 42 tractor. engine surges, blows oil
SOUNDS LIKE YOU HAVE A AIR LEAK AND SOME BAD GAS AND YOU MAY WANT TO CHANG THE OIL 1 MORE TIME LETME KNOW IF THIS HELPS IF NOT ILL DIG IN TO IT WITH YA
Oct 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have got a Craftsman model 917.270821 19.5 electric start 42" mower and cant get it to start I have replaced the starter and had the battery checked and all is good there, but dont seem to be gettin
check the wires from the back of the ignition and also the small wire that connects to the starter, if you get a 12v test light check each wire individually by holding the test light on the wire and have somebody turn the key, the test light should come on if the power is going through the wire.
If there is no power the ignition may need replacing
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsmans31c707 16hp riding lawn hard to turn over wont start
i had the same problem ,replaced the battery,and starter
turned out the muffler was plugged with a wasp nest,also ended up re-adj the valves later on!!!
Mar 17, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
