SOURCE: Samsung tablet isn't connecting to
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
SOURCE: I have the Archos 101
I had the same problem with my third Archos 101 (I've had two replacements to the first one I bought in June 2011). I just got the third one two days ago and it wouldn't connect to my WiFi like the previous two would. I had to add the 101's MAC address to my router's setup and now I'm connecting to the Internet. Alternatively, if your cell phone supports tethering (my HTC Tilt does) you can tether your 101 to access the Internet through your phone. Mine is working well that way....for now.
SOURCE: authentication problem when trying to connect to wifi
This tablet is running Android ICS. If the wireless you are connecting to is using WPA or WPA2 security you will need to set it to WEP or none for your tablet to work. This is known bug.
SOURCE: why won't my kurio 7" tablet connect to wifi
I had this problem with my son's Kurio over Christmas and found that connecting to wireless in Kurio mode was impossible. If you go to the parental mode and click the switch to Android button there are settings for the wifi in the Android platform settings. You can set up there and then go back to the Kurio safe mode for the children to use. Hope this helps...
SOURCE: Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
