SOURCE: Dolphin pool cleaner stops after 3-5 minutes
It is usually either the power supply or the motor unit or both. None of those items are considered do-it-yourself repairs. For information on sending the unit in for service you can check with the manufacturer at www.maytronicsus.com or try us at www.arrowpools.net. If the unit is several years old and in need of repair and also the replacement of wear items such as brushes and/or tracks, it can be cost prohibitive to fix. It is helpful if you get the serial number from the units casing when you contact us or Maytronics so we have an idea of how old it is.
SOURCE: instruction for changing yellow track on pool cleaner
Thank you for posting your question here on Fixya.com.
You remove the side plate by pulling the six screws inside the unit to expose the track. It is a bit of a challenge getting everything to line back up because the new tracks are stiff and tight but once you stretch them a little you can put them on and get the unit back together. If you would like a quote on the part (our web store is not quite finished yet) please use the contact button on our site found at www.arrowpools.net. As a repair center we can usually beat the prices of any of the aftermarket parts centers and if you have further need of technical assistance, we provide that too.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Testimonial: "Very helpful,we just have to accomplish the task( waiting for the track to be delivered)Favorite placed your site"
SOURCE: DOLPHIN DIAGNOSTIC AUTOMATIC POOL CLEANER STARTS AND STOPS
There may be moisture building up inside the motor housing. Try to Open it. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Maytronics-Dolphin-Repair.html
Then make sure no moisture accumulated in the circuits. Mine got the same problem.. after running trouble free for several years it suddenly stop running after the first few minutes..when i opened it a lot of moisture in the circuit. I tot it was toasted. so i took my hair blower and sealed it back and replace the moisture absober (it was soaked).. after first run it would run only the SELF TEST mode.. i tried several method to make it run all the way to the main program.. the solution.. start it and make sure it will not tilt in the first 10 minutes before you let i run sideways to the walls, this makes the program run back to normal.
SOURCE: stops running after about 2 minutes
Question the manufacture about a new circuit board.
The Pool Tech
SOURCE: Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
