I never seek answers to such serious questions on the forums. Air conditioner often break, it's good that I found a website that has information on all brands and possible breakdowns of air conditioners. I share with you a link to this wonderful site. https://airerrorcode.com/haier-air-troubleshooting
Likely means your AC is working outstandingly well. ACS make water, that's what they do. If it isnt making water there is normally a problem. Put a permanent drain on it.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Check your owner manual for instructions
if you have to drain it after that time then that indicates that there is a float level sensor that stops the unit from putting water on the floor
If all else fails get in a service technician under a warranty check
SOURCE: haier air conditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=1797 Hope this helps! ;)
SOURCE: Haier air conditioner # HWR06XC6
I have the same air conditioner and have call Haier customer support and they are also unable to tell me where the drain is. The manual says not to drill holes in the trap but I think that is the only option.
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
SOURCE: Where do I find the air conditioner drain tube
the tube is located on the passenger side firewall you can see it from under the car where you will have to be when you clean it out with either blowing air into it or clean it out with a coat hanger. just becareful not to push to far inside so you don't poke a hole into the evaporator. Hope this helps leave a comment. By the way it is usually a little rubber tube hanging out of the fire wall.
SOURCE: where is the drain hole
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
