Question about LG Heating & Cooling
I have an LG air conditioner. Screen says i need to drain the tank. There is a small black plastic lid to unscrew at the bottom but nothing comes out. What do i do?
  • LG Master
  • 4,289 Answers
Don't worry about low humity produces very little watrt
How to Remove Water in an LG Air Conditioner Hunker
Posted on May 23, 2018
SOURCE:
SOURCE: Plastic lid broken
Called Wolfgang Puck production center at 800 275 8273 and was successful in ordering the part for the food processor.
Posted on Apr 29, 2008
  • 334 Answers
SOURCE: I have a portable air conditioner and the water
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Posted on Jun 11, 2009
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Posted on Jun 23, 2009
daddyo742001
  • 70 Answers
SOURCE: air conditioner dripping water
Try pouring some bleach in drain.
Posted on Jun 28, 2009
  • 13 Answers
SOURCE: we just bought a Danby DPAC120068 air conditioner
Air conditioners produce water as a by-product because they cool air
below dew point. This hose is for water to drain. Take to drain or route
outdoors.
Posted on Aug 04, 2009
How do I remove the Main PCB from an LG LMU24CHV note not 247HV
Very easy. Use knoseplayer and hold both broken plastic together and then slowly remove ur board. Tnq
Sep 02, 2015 | LG LMU247HV Air Conditioner
I bought lg portable 9000 btu air air conditione two days ago. The unit fills up with water every few hours and the drain plug does not work. I have to move I it outside and tip it over to get the water to...
Hey there. I bought the same AC unit and was experiencing the same issue. Wouldn't drain, etc...
I'm happy/embarrassed to mention that there is a rubber grommet inside the drain plug that I did not see before. It looks like it's part of the plastic drain, but it's a rubber cap. So when you unscrew the plastic cap, there is another rubber plug you have to pull out.
Doh!
Hope this helps.
-C
Jul 05, 2012 | LG LP0910WNR Air Conditioner
How do I drain the water tank in my LG LP0910WNR Air Conditioner
tienes que ver por la parte posterior un tapon de color ***** yquitarlo y luego sacar un corcho de goma y el agua saldra
Jun 12, 2012 | LG LP0910WNR Air Conditioner
How do you drain water from a LP1010snr air conditioner?
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Drain the water (small amount actually) in the shower. Note: There is a cap towards the bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine.
Apr 17, 2012 | Heating & Cooling
I purchased and LG Model# LP1010SNR on 8-3-10 at Home Depot. It was a floor model and did not come with an owners manual. It has a digital display screen. It is intended to run for several hours at a time...
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
Aug 04, 2010 | LG Heating & Cooling
How do you drain the drain pump in lg front load washer washer spilling the water that is inside
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
Jan 22, 2010 | LG WM-2277HW Front Load Washer
Bottom Plug Leaking Water Tank Bone Dry /Everstar mpk cr 10000btu
you said that it has not been used for 3 yrs then maybe the tube leading to the water drain is clogged. try to clean it
Aug 21, 2009 | Danby DPAC8020 Air Conditioner
LG WD 3243RHD
The crackling noise you're hearing is something is inside the drain pump and hitting the obstruction.  It's possible that the drain pump has been severely damaged to the point that the pump will have to be changed.  You will need to have a qualified LG technician diagnose the problem.
May 06, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Heating & Cooling Logo
43 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
