Model # is 917.276824
Hello Larry Reese,
I typically recommend going everywhere ELSE...
but at times like these... SEARspartsdirect might
be the obvious choice... (?).
Water Filters Lawn Garden Appliance Parts
You will have to search foe a "SERVICE MANUAL"
Personally...
I would RATHER look on "MANUALSLIB" at..
ManualsLib Makes it easy to find manuals online
Hope this works for you...
Carnac the Magnificent
SOURCE: tri9ed adjusting valves now on 18hp ohv. now makes
exhaust is by exhaust pipe, sonds like the valves are hitting the piston head. loosen up fast
SOURCE: Tecumseh 16 hp ohv adjustment
It is always best to have the exact model number of the engine you want to work on. Here is a helpful link:http://www.tecumsehpower.com/CustomerService/BSI.pdf
SOURCE: 2005 model Murray 42 " cut with 15 hp OHV engine.
Oh yes they were right !! This happened to my unit last summer, those intake and exhaust have to at least checked every time you tune up so for most that is a seasonal check to keep everything in check.The magnet inside mine got ripped off the inside wall of starter casing. Go to smalleng.com they have a video for this and all you have to do is find out the gap numbers, that local repair shop of yours will be happy to give you those numbers. Now get er done!! Good Luck....
Testimonial: " I am used to the old type engines and never thought of adjusting valves. The repair shop said the would do it for $32.50 and show me how. Thanks ;-)"
SOURCE: how to adjust the valves
Here is one solution for doing it and I will repeat with the Briggs suggested maintenance procedure.
http://pkjones.hubpages.com/hub/Hard-to-start-Briggs-and-Stratton-engine
Scroll down to ADJUSTING OVERHEAD VALVES.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
Remember, proper setting of the overhead valves is important to insure that the ACR (automatic compression release) system operates correctly enabling a much easier start. Good luck.
SOURCE: what is the valve adjustment?
its the clearance between the rocker arm and the valve on briggs engines i set them to .006
