Question about Microsoft Xbox 360 Console
Data card broad band wireless connection
How do I connect to xbox live using a wireless router?
  • 79 Answers
It should be the same way as if you were using the direct input method, of course, you would need one of these...
http://www.xbox.com/en-US/support/systemsetup/xbox360/accessories/wirelessnetworkadapter.htm
Please rate if useful, thanks!
www.360solutions.eamped.com
Posted on Nov 25, 2007
I dnt know my WPA passphrase for my xbox live and now i cnt connect.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the Xbox, laptops and orcomputers with these router's wireless settings. Then the Xbox, laptops and desktopcomputers can communicate with your wireless router.
May 28, 2011 | Zhone (6218-I2-200) Router
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
I got a two day gold pass and a xbox 360 i also got tmobile broad band internet on my pc so how do i get started with xbox live without an adapter or do i need an adapter
Requires a Router/Switch
(2) ethernet cables
Using your PC as the main Internet Provider, connect one cable from the PC's ethernet jack to the WAN jack/port of a router. Next hook up your XBox to one of the wired 1-4 jacks/ports on the same router with the other ethernet cable.
Mar 09, 2011 | Microsoft Xbox 360 Console
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
Aug 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Xbox360
Hello taz1028,
In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
Sincerely,
Agent Xiong
May 31, 2008 | Microsoft Xbox 360 Elite Console
X box
Sometimes Cable providers require you to add your X-Box MAC address to the account so they know where to send the IP.
Feb 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
