Whei i replace the condensor the fan will come on but not the compressor .this is a fridgeadaire unit before nothing would come on
    Problem Solver:
  • 15 Answers
Check and make sure you have the proper line voltage. 120volt on each leg?
Posted on Aug 20, 2009
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
I replaced condenser fan motor put it back together now nothing " compressor or fan motor not working
What is power to unit and what type of unit is is ? Split system needs 24v to Condensor . And a dual pack need a call from tstat also. Check if u have a dual capacitor wired correct.
Sep 15, 2013 | Heating & Cooling
How soon after replacing the condensor fan, is it supposed to kick on?
Condensor fan should start when the compressor starts. If the condensor is hot at top and bottom, turn the refrig off and check the fan for power, should spin freely by finger, and coast to a stop.
Good Luck,
Bill
Aug 17, 2012 | GE Refrigerators
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
The AC in my 2004 Honda Accord only blows cool air when I am driving at higher speeds. When I drive slow or am stopped, it's warm hair coming out. My mechanic said the compressor isn't working properly...
it is a premature failure, That does indicate a bad/failiing compressor, or low oil charge, to low freon. If you trust the mechanic then go witht he compressor replacement and condensor. Unfortunately most oarts stores/shops require the condesor to be replaced for warranty purposes on compressor replacements.
Jul 22, 2009 | 2004 Honda Accord
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Jul 02, 2009 | Bryant 462AJC021BA Air Conditioner
Freezer not freezing, fan in rear bottom of unit not running, condenser extremely hot to touch. ge gdl20kcsabs
Hi, If the compressor is running but the fan is not, you will need to replace the fan motor. First make sure that there is nothing stopping the fan blade.
If you have a window or box fan, let it blow on the compressor to cool it down. This will help you get by until you can replace the condensor fan motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Refrigerators
Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
