Question about Bosch Evolution 500 SHE55M05UC Stainless Steel Built-in Dishwasher
Bosch SHE55M05 does not drain. I've cleaned the filters and removed an internal cover and removed debris. Still not draining....what's next?
5 Suggested Answers
jan mczeal
  • 632 Answers
SOURCE: water not draining
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Posted on Sep 04, 2009
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
samrat_babui
  • 296 Answers
SOURCE: Bosch SHE45M - Drain problem
Hi..
please check whether you have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed or not.
thanks
Posted on May 04, 2009
tbirdfan1
  • 3051 Answers
SOURCE: G7856 showing Fault Code F26.
Hello there again
I dont know if you got disconnected or just left the chat room but please try this
take out the bottom white basket so you can see the bottom inner of the dishwasher, then take out the centre filter and remove the silver L shaped plate so you can see down into the lower
tbirdfan1 says:
white inners......(may have water in it) on the left you can see a small white double dome with a silver clip going over it.....release the clip and pull off the dome inside you will find a pump wheel check this
tbirdfan1 says:
spins freely by flicking it round with your finger.
tbirdfan1 says:
.if you cant see it due to water then either feel for it or remove the water.........if it does'nt spin...free it...if it does spin easily then put it all back
tbirdfan1 says:
together and do this...... turn the control dial so it points upwards to the Hazard warning shape.........then turn on the power......wait a minute and then turn the control to the water drain
tbirdfan1 says:
symbol (arrow pointing to water) then hit the green start button...all being well you should hear the pump you've just checked spinning and pumping the water out
tbirdfan1 says:
the machine reset button is hidden under the 2 plates at the lower front of the machine but the screws are tricky to get to. try the pump and control part first.
tbirdfan1 says:
im still here hjust to let you know
tbirdfan1 says:
and one other thing that could be causing this is the float switch may have been inavertantly activated
tbirdfan1 says:
this would throw the code that you re getting
Posted on Jan 01, 2010
My Bosch 300 does not have a little round plate nor a square plate below my drum opening on the exterior of the washer like many posters have indicated. How do I get access to my drain filter?
These Bosch machines are similar to some Kenmore washers (he4t). You can remove the lower front cover. Behind this cover, you will find a white plastic housing that has a s tree off cover. Be ready with a catch pan! Remove this cover and water and collected debris will come pouring out in a large gush. If this becomes clogged, the washer may send error codes and fail to spin and drain properly. You can fish out additional debris with your fingers before replacing the cap and the lower front cover.
Nov 10, 2016 | Bosch Washing Machines
My Bosch next premium washer will not drain
1st... check the hose for any kinks or blockages. If that is clear, there should be a round cover on the bottom of the machine in front. Remove this and you will find a cap. Remove this and clear the filter of any debris
Feb 12, 2015 | Bosch Washing Machines
Bosch goes straight to clean cycle
I had the same issue, for me this is what solved it.
Clean out the drain filter, remove any water that's still in there using a ladle/sponge/cloths, remove the impeller cover and make sure the impeller is spinning with no resistance. may be some food debris that got stuck or the filter may just be very clogged. Give it a try, it's a simple procedure:
This is from Bosch UK's youtube page:
http://www.youtube.com/watch?v=hfw3vliCf4c
Worth a try!
Sep 11, 2014 | Bosch Dishwashers
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
The washer will not drain I cleaned the bottom drain out and it was full of something that felt like kitty litter (it was not kitty litter) something fell apart when I was washing. I attempted to run a...
Your drain system is clogged with debris. Remove the filter from the bottom left door and look straight back inside the drain system, you will see more debris inside. Do not use a sharp object to remove the debris or you will puncture the rubber bellows. From the back of the machine, remove the back cover. At the bottom of the tub you will find a rubber drain hose that leads from the bottom the tank to the drain filter. Using your hand, gently squeeze the rubber drain hose to "massage" the leftover debris inside. This should help clean out the debris. WARNING: This will cause a major rush of water to come out so be prepared. Good luck
Jun 18, 2011 | LG WM2016C
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
Bosch dishwasher SHU4000 problem starting, not draining
Drain problems are almost always going to be a clog. Disconnect the drain hose from the air gap vent at the sink top. Place a bucket under the hose and run the drain cycle. Unit should drain. If not, clog is either in drain hose or under the dishwasher's internal filter. Remove filter. Locate the item causing the clog and remove it. If nothing is found here, the problem will be in the air vent gap filter itself. Disconnect the other hose and remove the air vent gap from the sink. There's a small cap at the top of the filter. Press the clips in to remove the cap. Flush the unit with water or use a thin, long blade screwdriver to remove the debris.
Put it all back together and test again. You should be fine.
Mar 20, 2010 | Bosch SHU4006 Dishwasher
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Bosch Evolution 500 SHE55M05UC Stainless Steel Built-in Dishwasher Logo
147 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
