Question about Hitachi 50V500 50 in. HD-Ready LCD Television
2004 Phillis 47 " flat panel ghost image
Their is two images on the tv of the same object. Have any ideas? Think it is repairing??
Thank you
  • 50 Answers
Yes, it called ghost image. You can try to go in the service menu, and scroll to ghost image. Turn tv off, wait till red light stops blinking, and then on the remote press the input button. at the same time press the power button on the tv. this should put you in the service mode. If nervous about this call tech assist at Hittachi.
Posted on Feb 09, 2008
Ghosting lines on a samsung LN40A630M1F
The TCON Board or the LCD panel is faulty. Can confirm only by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
May 16, 2016 | Samsung Televison & Video
Ghost picture (faint double image)
It sounds as if your optical lens are out of alignment on your tv..
Sep 30, 2015 | Hitachi 50V500 50 in. HD-Ready LCD...
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
Ghosting image on samsung led tv in 3d mode
well i think i have got something for you...try the link samsung lcd tv ghosting
Oct 09, 2010 | Samsung Televison & Video
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Vizio P50 screen refresh
power supply.Definately will need to be replaced. Im actually looking for one to replace myself.TV repairs charge 1200 to repair.
Nov 01, 2007 | Vizio P50HDTV10A 50 in. Plasma HDTV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
253 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
