SOURCE: need to know where front connectors for firewire usb go
ok..here is the link from the official MSI site ..download the pdg manual..and good luck instaling...
bye;)
SOURCE: Looking for line level input or a card I can use with line level input.
There is high performance stereo input PCMCIA cards, not cheap, also a cheaper alternative stereo input USB devices.
Check them out on the Internet, use Google search.
SOURCE: microphone not working on ps3 w two connections
you should be able to plug each mic into a usb port. (they are the holes on the front of the machine) they each need to be plugged in separately. If this doesn't work there may be a problem with the usb port.
What you want to do won;t work and can damage your laptop and or Bose.
If you want to play sounds from your laptop to your Bose, you need to plug an audio lead from the headphone socket on your laptop and connect the other end of this audio lead into the audio input on your Bose Sound Deck (if it has an Aux input).
