''BOOTMGR is missing'' I can't boot from Windows XP CD
''BOOTMGR is missing'' I was watching movie on my PC then suddenly my computer restarts then I got this first message ''Floppy Disk Fail(40)'' after that when I press ''F1 to continue'' the second message was ''BOOTMGR is missing Press Ctrl+Alt+Del to restart'' then my pc will hang up.
So what I did was I check the CMOS settings I saw that the Boot Up Floopy Drive was enabled that I think it must be disable(correct me if I'm wrong). Then after I restart my computer the ''Floppy Disk Fail(40)'' error gone. The only problem was ''BOOTMGR is missing'' see what I tried below.
Specs:
OS: Windows XP.
DVD-ROM
Desktop
What I tried:
- I changed the boot sequence to the BIOS changing ''Boot Up Floppy Drive'' [Enabled] to [Disabled] *I think Problem Solved*(correct me if I'm wrong)
- I already changed the boot sequence to the BIOS changing the ''First Boot Device [Hard Disk]'' to ''First Boot Device [CDROM]''.
- I removed my other hard disk on my computer.
- I disconnect IDE cables then reconnect it
- I disconnect the wires on the Hard Disk and reconnect it.
Problem:
- I can't boot from the Windows XP CD even if my First Boot Device was CD-ROM im getting the same error the message was --> ''Press any key to boot from CD.....'' then if I click any button nothing happens then after that the message ''BOOTMGR is missing Press Ctrl+Alt+Del to restart'' then my pc will hang.
I read the forums but doesn't solve my problem that to fix the ''BOOTMGR is missing'' error is you need enter ''Enter Recovery Mode'' or to the console type (caps on) bootcfg hit enter
3/ type (caps on) bootcfg /default etc etc....
Any help will be much apperciated.
    President:
  • 1,383 Answers
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Posted on Aug 01, 2009
Bootmgr is missing
are u use windows xp?
try to boot you computer from OS cd then choose option to (r) repair in first screen you os cd option.
then choose c/windows
in command promt type fixboot and enterthen type y for confirmation
after that type chkdsk /rthen enterwait until you system running chkdsk then restart your pc.
if not successful...
reinstall your windows without format..
Nov 05, 2012 | Advent 4211c Notebook
Black screen bootmgr is missing cntrl alt delete to restart win xp hp pavilion 7955
  1. Boot your computer with the Windows XP CD.
  2. On the "Windows XP Professional Setup" menu, select "R" for Recovery Console.
  3. You will be prompted to select the Windows installation to repair, usually option 1.
  4. Enter the Administrator password, followed by enter.
  5. At the command-prompt, type "fixboot" (excluding the quotation marks) and press enter.
  6. Press Y and enter to confirm.
  7. Remove the XP CD when complete, and Restart the PC.
Jan 24, 2011 | Computers & Internet
When I start the PC it says "BOOTMGR is missing"
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Nov 12, 2010 | Acer Aspire 6920 Notebook PC
My computer wont load . It says missing bootmgr press ctrl alt del to restart
Bootrec /rebuildbcd
May 20, 2010 | Toshiba Satellite M305-S4826 Laptop
Bootmgr is missing on Windows XP System. Gateway
Bootrec /rebuildbcd
May 15, 2010 | Gateway ML6721 Notebook
Download this Recovery Console BootCD
http://www.thecomputerparamedic.com/files/rc.iso
Burn the image (ISO) to CD.
Boot from the newly created Recovery Console BootCD
Log into the Administrator account (press 1 then press enter)
On the command prompt type: chkdsk c: /r (and then press enter) Note one space after "c:")
Once CheckDisk has finished repairing the faults, type Exit, and then Restart (remove the BootCD)
Mar 29, 2010 | Gateway ML6721 Notebook
Bootmgr is missing
Insert the original CD-ROM that you used to install Windows XP.
Restart the computer, and tell it to "boot" from the CD-ROM,
instead of the usual disk-drive.
Eventually, you'll get to a screen that asks "install" or "repair".
Choose "repair", to see if Windows will repair the 'BOOT-MANAGER' file.
Jan 04, 2010 | Acer Aspire 5536-5224 Notebook
BOOTMGR is missing
If XP, boot the XP CD, go to recovery console (R at first prompt) Type the command BOOTCFG /REBUILD
Microsoft instuctions are here:
http://support.microsoft.com/kb/330184
If Vista boot to the Vista DVD, and run a startup repair per this:
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Dec 18, 2009 | Toshiba Satellite Pro L300 Notebook
Bootmgr
format ur laptop and get ur problem solved
Sep 05, 2009 | Acer Aspire 7520-5185 Laptop
Bootmgr missing
Windows Vista?
Insert the installation CD. Once it boots from CD, click "Repair Your Computer", select the drive, and then "Startup Repair". This should fix it.
More info here.
Apr 16, 2009 | Computers & Internet
Computers & Internet Logo
778 people viewed this question
David Payne
David Payne
