SOURCE: finding treble and bass adjustments on my stereo
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
http://vault.alpine-usa.com/products/documents/OM%20CDA-9835.PDF
Good Luck Please Rate FixYa!
SOURCE: how to adjust treble and bass
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
SOURCE: Cannot Set the Treble & Bass
You DO NOT NEED imprint software to tune your bass/treble so don't waste your money. Go to "A. Sel" then graphic or parametric equalizer based on your settings in "setup," then go through either the 5 or 7 bands as you have setup and adjust for each frequency. On graphic EQ, you have more dynamic control. These are what each band represents by frequency from 1-7: 60hz, 150hz, 400hz, 1khz, 2.4khz, 6khz, 15khz. Hope that helps.
