Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
A picture of a service guy appears what does that mean and a fl lights up
  • 128 Answers
Ths normal means an open safety switch. Usually the pressure switch is bad. Jump the pressure switch to confirm
Posted on Aug 30, 2009
I have a 22' Dell monitor that goes black after a few minutes. I can still see the images in the background. The monitor's power stays on and when I turn it off then back on it comes back on with such a...
Hi
I think you have TFT monitor? If you are having TFT, the issue was occurring because of two problems.
1. Might be your monitor FL invertor was faulty.
2. Or your monitor FL light having problem.
Check with any local service person. Whether FL invertor or FL light having problem?
If you found the solution is helpfull please vote for me, Thank you.
Mar 22, 2011 | Dell Computers & Internet
What does FL flashing on the screen means?
FL means Full (or Full Load). The camera has no more storage space to keep your pictures, so doesn't allow you to take them.
Inexpensive cameras like this do not have the option to add extra storage, so you are limited by what the manufacturer installs.
Along with the camera, you should have got a disk and cable in the kit. What you need to do is download the pictures onto your computer, then delete them from the camera memory (usually menu options on installed software).
At that point, your camera should be fit to take another set of pictures.
Mar 02, 2010 | Cobra DC150 Digital Camera
I have a Jacuzzi spa that has a FL on the read out.
the FL code is usually an insufficient flow fault. you may have a dirty filter or a faulty flow switch/sensor.
Dec 27, 2009 | Pool & Spa
01 gsxr that fl code came on and oil light is on.
It is not safe to drive with the oil light on, you risk major engine damage. It means low oil pressure. The FI light means a fault with the fuel injection system. You will need diagnostic equipment connected to the bike to read the fault code(s). Most likely this will be at a shop.
Jun 29, 2009 | 2001 Suzuki GSX-R 750
On the gage cluster what does F1 or FI mean
The Fl lamp lights up when the computer finds a malfunction in the programmed Fuel Injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Nine of the 33 codes do not show symptoms since the engine still runs okay. If the Fl light just stays on then the engine will not run because the computer will not let it run, (except in two cases).
"MIL" translates as "Malfunction Indicator Lamp ".
This is what the service manual says:
" The PGM-Fl MIL denotes the failure codes ( the number of blinks from 0 to 33 ). When the indicator lights for 1.3 seconds it is equivalent to 10 blinks. For example, a 1.3 second illumination and two blinks ( 0.5 second X 2 ) of the indicator equals 12 blinks. Follow code 12 on page 5-26.
When more than one failure occurs, the MIL shows the blinks in order of the lowest number to the highest number. For example, if the indicator blinks once, then two times, two failures have occurred. Follow codes 1 and 2 on page 5-12."
BOTTOM LINE > A blinking light that can't be understood, combined with instructions that can't be understood make the entire Honda "malfunction alert system" totally worthless and a pain in the neck to the owner. Why can't someone in Japan write a computer program that would render something like " Code 23 error " instead of a blinking light that means nothing because it is not user friendly.
You asked what the FI light means. It means you are forced to take your bike in for service at a Honda shop and pay big bucks to the dealer for something you could have done yourself for $12.00. This is a built-in money maker for Honda dealers.
Please rate this answer. Thanks.
May 16, 2009 | 2001 Honda CBR 929 RR Fireblade
F1fault appearing on dash
The Fl lamp lights up when the computer finds a malfunction in the programmed fuel injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Have a drink of Saki and think about THAT for awhile. Then get back to me with the code ( 0 to 33 ) and I can tell you what the code means.
Please rate this answer as four diamonds.
With four diamonds and some Saki I can now rest for awhile.
Apr 06, 2009 | 2000 Honda CBR 600 F(4)Y
My ac is carrier company window a/c its indicating {fl}
From the manual.
Message on the display(electronic models) E4 1. Failure in the inside temperature sensor E5 2. Failure in the outside temperature sensor FL 3. Dirty filter
To fix vaccume  (or wash your filter) then  hold down "Select"(or "Mode") and "-" (or "^") for 3 secconds.
Jan 30, 2009 | Carrier 52PQ307 Wall/Window Air...
Blue Color Convergence wont adjust
yes by all means . I will post a link where you can get your replacement ICs along with free installation instructions with pictures. They also provide free on-line instant messaging while your doing the repair which only takes about an hour from start to finish. I am one of the support techs. Your model uses STK392-110 or STK392-120 either IC interchanges with each other except the 120 is a better IC runs cooler.Heres the link.You will need to replace both ICs
http://servicemanuals.vstore.ca/
Apr 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
On the top screen where it says the amount of shots left for a sequence, it says FL
FL means that the full amount of space on the card is available...it doesn't give you an amount like say the d70 which says you have , say, 1.1K available of space...the d21x goes in reverse and starts counting how many pics you have taken...the FL becomes a number at 99 and goes down from there depending on how many pics you take.So you then end up with a number on top instead of FL and a number below indicating how many pics you have taken.
Hope this helps.
Jan 28, 2008 | Nikon D1X Digital Camera
What FL stands for?
FL means change filter media
Sep 13, 2007 | Carrier 38CKC042 Air Conditioner
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
190 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
