Question about Kenmore Elite Oasis 27052 Top Load Washer
Every load is unbalanced - Kenmore Elite Oasis 27052 Top Load Washer
  • 3 more comments
  • james_pye Aug 01, 2009
    we have taken machine apart and cleaned. water remains in the bottom of the tub, Will this cause every load to be unbalanced?
    bea
    My Kenmore washer is 3 years old. Within the past 3 weeks every load is unbalanced. I rearrange and take items out of tub but this has no effect on the unbalanced code (uL)
    When we took the machine apart water remained in the inner drum bottom which is enclosed.How can we drain the water is there a plug?
    James
    James
    Is the control board the computerized part of the machine? Jameswe took the washer apart and there was nothing visible to cause the unbalanced.Is the control board the computerized part of the machine?
    James
  • 3,037 Answers
A Bad Bearing or broken tub supports are the cause of this.
You can get a new one through Sears Parts Direct, either go to a local store, call them, or check out their online website. Let me know how this turns out
Benjamin
Posted on Aug 02, 2009
  • Kenmore Master
  • 19,396 Answers
To start ensure that the machine is balanced. Ant that the floor is at level.
If the machine is balanced, unbalance can be caused by an object that slipped under the spin basket. If an something end up under the spin basket it will cause out of balance. To check this remove the spin baket and check underneat.
Here instructions.
If that does not fix the problem, then it is a faulty control board.
Posted on Aug 01, 2009
  • 10,865 Answers
Helllo James. I can help you. Every waher has to be level front to back and side to side. Check yours and adjust it if it is not level.
That said, if your machine is level and still always unbalanced the problem is a bad drum bearing. To check for this by spinning the drum by hand and checking for excessive play. If you don't know what is considered excessive check on your friends washing machimes to get a sense of what is normal.
Finally, it is also possible that the drum spider is broken. If you have excessive play you will most likely have to have a washing machine tech. fix it.
    President:
  • 1,723 Answers
Can you please restate question and be more specific...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
Whirlpool awoe 8761
Is it always loud or just when it is a full load. If the load is unbalanced it will be loud. Most F/L washers today have some kind of unbalanced load detection, but they are not all that great. If it spins quietly when empty it is just an unbalanced load. Don't over load and don't mix rugs with clothes, pillows, etc...
May 19, 2012 | Whirlpool Washing Machines
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
My washer's digital time screen changes from the time remaining to a symbol that looks like "UL".
This error code indicates that an unbalanced load is detected.
Click the following to learn more about unbalanced loads in the BravosTM washers. The example is for an impeller washer but is applicable to washers with agitators.
Is the wash load balanced?
If the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause.
Is the washer level? Does the washer rock when pushed against the corners?
If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened. See the Installation Instructions for details.
To remove the error display, press Power/Cancel or Pause/Cancel once.
Jan 02, 2011 | Maytag Bravos MTW6600T Top Load Washer
Noisy when trying to spin. display uL instead of time remaining. Stopped, opened lid and redistributed load. Started up again. cycle continued but still displaying uL. Not sure if load still unbalanced?...
REPLACE YOUR SUSPENSION RODS. You can get them at a discount applicance parts store online for about $60. Our washer is about 8 years old and has been getting unbalanced on every load. I replaced the suspension rods tonight and and it solved the problem.
Jan 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Jul 26, 2009 | Kenmore 24032\24036 Top Load Washer
Empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
