Question about Acer AL1916W 19" LCD Monitor
I had the same exact problem.
I locked my computer came back an hour later and the screen was black, the light on the monitor was orange and the PCU was still running. I turned off the PCU and the monitior and turned them back. Still I saw "Acer" then "No Signal" and finally the monitor shut off. I just bought the computer less than a year and a half ago.
    President:
  • 1,383 Answers
First power up the computer then press F8 key then if you see safe mode and other menu then enter in enable vga mode then go to control panel and change screen resolution to 1024*768.
If you can;t see safe mode and other menu.
Then open the cpu cabinet then refix RAM memory .
clean dust from circuit and RAM.
Pull cmos cell from motherbord for 15 minutes so all bios settings are defaults.
Then check.
Posted on Aug 01, 2009
Hannspree HF289H Black screen SIngle orange light once and completely unresponsive
There is two chance for theis problem. 1) there is missing voltage to the back light inverter boadr or 2) the back light inverer is faulty. Check the power supply volatge to the back light inverter board. Normally its 24v for all lcd back light inverters. If the power supply is ok then you have to replace the back light inverter board.
You can check is there is any picture on the lcd screen by the help of a tourch . light the tourch near to the lcd screen and wach the screen from different angel while the PC is in ON position.. in some angle you can see the shadow of picture if every thing else working fine except back light.
If so there is powersupply missing or back light iverter is faulty. You have to replace the back light inverter board with a new on because there is no repair possible with the board. Also the spares will very difficut to get.
Ajin
Apr 01, 2012 | Hannspree HF289HJB 27.5 in. LCD TV
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
At the desk top, I moved the mouse to begin and the screen went black. All it gives is a blinking orange light. Pressing the switch doesn't matter. Upon rebooting , blinking light persists while you can...
Sounds as though you have a backlight issue. How old is the monitor?
The keyhole with the lock sign is for a security lock to lock the monitor to a desk so it cannot be stolen.
Mar 08, 2011 | Acer AL1916W 19" LCD Monitor
My screen takes 1 hour to light up.
Hi
This issue is due to a faulty backlight inverter. This happens either due to loose solder connection inside the LCD or a faulty back light inverter. I'll suggest you to give it a hard reset by unplugging it from Computer and power supply for 6-8 hours. If the issue is not resolved then its a Hardware issue.
If you can deal with electronics and soldering thing then I'll suggest you to check for the back light inverter. Also, check for any loose connections inside it.
Check whether there is proper ventilation for air to flow through the back of the LCD.
Daniel Scott
Jun 12, 2010 | Samsung SyncMaster 932B LCD Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
LG Flatron problem
i get a black screen and an orange light in my lg lcd flatron whenever i turn it on.. i cnt use my pc because of this problem.. i hope u would answer my question...
u can email me at jmaonir@yahoo.com
tnx man :)
Apr 09, 2008 | LG Flatron L1710S 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
231 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
