Question about AudioBahn A2801Q Car Audio Amplifier
No sound amp powers up but i can not get any sound out of it. need advice. amp is a audiobahn a2801q.
  • 631 Answers
Re: no sound - AudioBahn A2801Q Car Audio Amplifier Car Amplifiers
Is the protection light lit?
Posted on Nov 25, 2007
0 characters
3 Points
Does an audiobahn A2801Q throw 1000 watts
Hello... I can help you with this question. This particular amplifiers specifications are as follows:
  • 200 watts x 2 @ 4 ohms stereo
  • 280 watts x 2 @ 2 ohms stereo
  • 560 watts x 1 @ 4 ohms mono
    These specifications are RMS power, which would mean continuous "real" power output. Hope this helps!
    20 year car audio/video installer
    Bay manager
  • Mar 15, 2011 | AudioBahn A2801Q Car Audio Amplifier
    Is the audiobahn a2801q 1 ohm stable in bridge mode?
    No it is not. You will melt that amp trying that. It is only good for 4 ohms mono and two ohms stereo.
    Aug 21, 2010 | AudioBahn A2801Q Car Audio Amplifier
    Just wondering ..
    square port (slot loaded) vented box tuned at 33 - 38 hz is the loudest deepest bass you can get
    Nov 18, 2008 | AudioBahn A2801Q Car Audio Amplifier
    AudioBahn A2301Q Car Audio Amp
    For the most common problems, a schematic diagram isn't required. What does the amp do when you power it up?
    If you're new to repair work, read through the following page. It will guide you through the most common types of repairs.
    Basic Repair Primer
    Let me know if you have any other questions.
    Jun 14, 2008 | AudioBahn A2301Q Car Audio Amplifier
    Wiring under tect support you can download manuals and get wiring diagrams for free
    Mar 06, 2008 | AudioBahn A2801Q Car Audio Amplifier
    My amp is on but the protection light stay's on!!
    Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
    Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
    Audiobahn A2800E Amp
    well it depends on your sound preferences, as well as what its going into(vehicle)would need more info to make such a sugestion
    Feb 08, 2008 | AudioBahn A2800E Car Audio Amplifier
    Amp a2801q
    Audiobahn A2801Q
    Product Description:
    Class A/B MOSFET Circuitry
    Volt Meter With Blue Illumination
    PWM MOSFET Power Supply
    Double Sided Glass Epoxy Circuit Board
    THD: 0.02%
    S/N Ratio: >100dB
    Frequency Response: 10Hz - 40KHz (+/- 1dB)
    Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
    Variable 18dB Low-pass Crossover: 30Hz To 120Hz
    Bass boost @ 45Hz: 0/18dB
    Subsonic Filter: 20Hz to 50Hz
    RCA Throughput Connections
    3-way Protection Circuitry: Thermal, Short Circuit and Overload
    Cooling Fan
    Cobalt Blue Illumination
    High gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
    1-year warranty
    Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
    Audiobahn 12' subs and audiobahn amp
    First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
    Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
    Dec 20, 2007 | Car Amplifiers
    No sound from audiobahn a8002v amp
    what readout are you talking about?have checked speakers yet?
    Apr 29, 2007 | AudioBahn A8002V Car Audio Amplifier
    AudioBahn A2801Q Car Audio Amplifier Logo
    90 people viewed this question
    Top AudioBahn Car Amplifiers Experts
    matthew walsh
    Level 1 Expert
    Tygh Duval
    Tygh Duval
    Colin Stickland
    Colin Stickland
    Are you an AudioBahn Car Amplifier Expert? Answer questions, earn points and help others
