Question about Alpine MRD-M1001 Car Audio Amplifier
I have an alpine mrd-m1001 getting curr message ho do you reset the amp
  • 655 Answers
Hello deeprajm,
Shorted or low impedance outputs can cause the "CUR" display. Power down everything and remove the speaker wires. If it will then power up without the display, the problem is probably a short in the speaker wire or voice coil, or the impedance load is too low. If there are multiple subs, reconnect them one at a time to isolate the bad one and then correct the problem. If the amp works properly with either of the subs but not both, rewire the subs for a higher final impedance.
If the amp still displays "CUR" with the speakers disconnected, there's most likely an internal fault that requires component level repair.
Hope this helps.
Posted on Aug 02, 2009
Got light but buffer are not working
the connections are not correct or fuse is damaged
Apr 26, 2011 | Alpine MRD-M1001 Car Audio Amplifier
It has no output and isnt reading that there are any ampres on the meter
hi
i looked at the manul and came a cross this if it helps
No sound is produced.
• The output disable mode is turned on.
• Refer to the instructions at "Output Disable Mode"
to turn the output disable mode off.
Jul 17, 2010 | Alpine MRD-M1001 Car Audio Amplifier
WHERE CAN I GET A BASS KNOB FOR ALPINE MRD-M1001
Any AUTHORIZED DEALER of this Product Although this Spacific Part May NOT be Available, Not EVEN From Manufacturer.
May 12, 2010 | Alpine MRD-M1001 Car Audio Amplifier
Amp keeps blowing fuses (alpine mrdm1001
Hello prabh_dusanj,
First make sure that the amp is not operating into too low of an impedance. If the load is OK, it's most likely a short in the output transistors.
Hope this helps.
Sep 11, 2009 | Alpine MRD-M1001 Car Audio Amplifier
Amp displays the letters curr
have you disconnected all inputs and outputs on amp and retried starting it power only? if so your amp has an internal solder bridge and must be repaired by authorized repair center. Repair it or replace it at wholesale price from www.godspeedaudioheaven.com
Jan 31, 2009 | Alpine MRD-M301 Car Audio Amplifier
Alpine MRD-M301
you could have a bad ground or the power wire could have a short i would start there
Jun 25, 2008 | Alpine MRD-M301 Car Audio Amplifier
Alpine mrd-m501 amp
Disconnect the speaker wires from the amp, then try it again. If the error message doesn't appear, try connecting the speaker wires back to the amp one by one.
The error message is due to some sort of overcurrent in the amp. If the error does not go away when the speaker wires are disconnected, the issue is most likely with the amp itself and will need professional repair.
Mar 18, 2008 | Alpine MRD-M501 Car Audio Amplifier
Alpine amp mrd-m605
The amplifier probably has shorted output transistors. If the amp gives the same error message with the speaker wires disconnected from the amp, the amp needs to be repaired.
Dec 30, 2007 | Alpine MRD-M605 Car Audio Amplifier
Negative speaker output touched chasis of amp.
check all fuses on the unit, pull them all.
look for a way of resetting the amp.
LEAVE THE MAIN FUSE OUT TILL THE INSTALL IS COMPLETE!!!
that way you wont short a screw driver across the terminals on to the chasis.
Dec 11, 2007 | Alpine MRD-M301 Car Audio Amplifier
Lights on, nobody home
Appears to be an issue with current. Is the speaker the correct impedance for the amplifier ? Have you confirmed there are no short circuits in the wiring ? I'm not familiar with this particular product,
The alpine catalogue gives recommended amp/speaker combos. If you don't have an aplpine sub, then look at the specs and find a similar one. You may be trying to load the amp too heavily and it will protect itself.
Nov 18, 2007 | Alpine MRD-M300 Car Audio Amplifier
Alpine MRD-M1001 Car Audio Amplifier Logo
290 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
