SOURCE: my bissell bagless vac has no vaccum. ihave
Have you checked the main dust channels from the hose leading into the bin? Have you brushed clean the main filter cones? Make sure all the filters have been properly cleaned *(and if washed make sure its completely dry before puttng back into the machine.) Also please check the beater bar, especially the dust channel behind it as it can get clogged badly.
SOURCE: I need to put a new belt on the vaccum cleaner,om
You can get any bissell belt you need at www.vacbelts.com
SOURCE: I am looking for the filter for the Eureka bagless
There should be an toll free # to call for eureka and they can direct you to the nearest authorized eureka service center in you area. If its a new model places like wallmart wont stock it. There are so many vacuum makes and models its impossible for any one business to stock every single bag, belt, filter etc. for them all. But a decent vacuum repair shop should be able to get it for you.
SOURCE: how do you replace switch on Epic 6500 vaccum
You may need a ROCKER device for the switch, however before you go there determine if you can hear an audible click when depressing the switch, or if the switch just springs up and down with no click.
A click means a rocker is needed. No click, just springing up and down with an occasional click means the spring attached to the underside of the switch button is fatigued, you need the button and switch mechanism, same location but above the rocker.
Also post the issue. If the lights are on and the vac won't start or stop, the switch is the problem area. If it starts and shuts off with the bag full light on it is more likely the control valve. If no lights come on your problem is in the cord or rewind and could be a failed rewind spool.
The best and genuine switch parts are best found only at an AERUS Elctrolux store
Look for my post from earlier today and you will have full instructions on opening and checking the control valve and the entire unit.
Post back with results
Testimonial: "Great tip, I already figured out that you had to pull the strips under the bumper but can't get them to unlock, is there a trick to that? Thanks"
SOURCE: finding a belt for vaccum
http://search.totalvac.com/search?keywords=Euro-Pro+Shark+Fantom+Compact+
Follow the above link,the belt is on the top right hand side of the page.
