Site not found error pxm 20 site not found error appear on screen when accessing air handling unit on pxc 36
  • 3 Answers
1. install the pxc 36 unit
2. reboot the system wait for around 30 mins. for the server to recognize the pxc.
3. reset standing alarms on the software done
Posted on Aug 02, 2009
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
Fix error code 0210 stuck
error0210 is probably the O key. I found this information from Lenovo Service Site. Hope it is usefull.
You can test your key codes on this site, and as others have already discoverd and from my past experience key code 28 indicates that your error is coming from the apostrophe key. Sometimes due to normal use, keyboards may not fully release a key after it has been pressed. I would recommend getting some compressed air and try cleaning the keyboard, it is possible something is stopping it from releasing.
Since it seems that you are having mulitple errors I reccomend is to verify that your drivers are up-to-date, you can do so from the Lenovo Driver Matrix.
However, if this does not fix your error, it is possible the error has something to do with the BIOS Settings. You may boot to the BIOS and set it back to factory settings and check if the issue persists. To enter BIOS press the F1 immediately after the logo screen appears. Prior to the reset back up all of your information so that you do not lose anything as a precautionary measure.
Also, as others have stated if your device is under warranty, you may contact your local Lenovo Service Center for further assistance.
Dec 11, 2013 | Lenovo ThinkPad Computers & Internet
Matrix addition, subtraction
There should not be any problem. There is however something you did not talk about. After you finish entering the coefficient of the second matrix (mat B) you should press the AC key. This way you exit the matrix editing utility.
Once the matrices are entered and saved,
Press [SHIFT][4] (Matrix)
Press 3: MatA
The label MatA appears on the screen.
Pres [+]
Press 4: MatB
At this point your screen shows MatA+MatB
Press [=] to get the result
[ [-36 , -92], [-69,-17],[-63, -71]]
Dec 03, 2013 | Casio FX-115ES Scientific Calculator
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
RUUD AIR CONDITIONER WHAT TON IS THIS UNIT THE COMPRESSOR WENT OUT AND I FOUND A 3 TON COMPRESSOR BUT NOT SURE IF IT WILL WORK FOR MY UNIT?
Look in the model number for a pair of numbers like 18, 24, 36, 48 ,60... these are the btu output of the unit... then divide that number by 12 to get the tonnage of the unit... for that compressor to work for you the unit should have a "36" in the model number...
heatman101
Aug 23, 2010 | Heating & Cooling
Error codes on samsung a/c type AQV09VB
If this is a split system where ac unit is outside. Look
on the indoor unit probably printed behind a wiring
access door. sometimes if you remove the filter where the sensing element would be, the code could be stamped there
Feb 16, 2010 | Heating & Cooling
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
A/C Size
This appears to be a 3 ton unit. The number 36 represents 36000 BTU`s. That would be 3 tons.
Nov 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
